ok here is the problem....my steering wheel cover is loose, now this is that piece where u press to honk the horn...i can basically move the whole thing...now what should i do...is there a way to snap it back into place(which i have tried) or should i take it to my mechanic??????????? has anyone had this problem??? im a lil worried because the air bag is right behind it..help!!!!!
Two screws secure the airbag. Tighten with a T20 or T25 Torx driver. Screws are behind the wheel. Turn the wheel 90 degees left from straight ahead, feel for the opening in back. Tighen that screw then turn the wheel 90 degrees right from straight ahead and tighten the other one.
AL
Red '98 SVT E0 3098/6535
DMD
other stuff
and a Bullitt fuel door
my entire air bag is out loose it is only held by the wire that connect to it, otherwise it just sits in place, when i pull out quick it falls out of place, is this similiar to your prob??
