Posts: 67 |
ok has anyone added a svt bumper to a pre 98. I am sitting here looking at this thing and it looks like it needs a good bit of body work, with the change in headlights and the grill. wondering if adding the mirko splitter to mt factory bumper would be less of a hassle. any opinions?
Youngest Retirey Ever
Posts: 4,051 |
Nope, never been done. Be the first.
Posts: 5,143 |
Originally posted by BOUCH96: ok has anyone added a svt bumper to a pre 98. I am sitting here looking at this thing and it looks like it needs a good bit of body work, with the change in headlights and the grill. wondering if adding the mirko splitter to mt factory bumper would be less of a hassle. any opinions?
boo yah...
Its really not that difficult... Just buy an SVT bumper, take your current bumper... Cut the top half off of it, do the same for the SVT bumper in the exact same spot... Then Plastic weld it together... Looks pretty good if you ask me...
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 498 |
its a little more then just plastic weld, i would say its a fairly difficult job, especially getting it to line up with the current body lines.
96' ATX Zetec- stock
96' ATX Zetec- Modded
Kenwood KDC-319
5.75"-2 MTX 12's
Roady XT
Custom door panels
Mystique Cluster/oil pressure
Getting repainted(in primer)
Pre98 Lip
SE skirts
Mystique front lip
dingless
badgeless
Posts: 979 |
Originally posted by ZetecGL: its a little more then just plastic weld, i would say its a fairly difficult job, especially getting it to line up with the current body lines.
Actually plastic weld would do a decent job of holding the bumper in place, there may be other products similar but that would suffice. Do what Alias jerk said to do, then sand down, prime, and paint. In fact you might not need to prime if you just sand down the entire exisitng paint job and paint over it. Just make sure the lines match up and it will turn out great.
My ride(Cardomain link) :
'95 Contour 16V Zetec DOHC, Teal , ATX
Born on Sep. 4, 1995
86+ miles
*LEDs mods are on their way!*
Posts: 1,150 |
u must not have searched much....
Posts: 3,570 |
I documented the process in a thread in pics and vids I beleive. Yup, here it is its definately NOT as easy as "oh, whip it up with some plastic weld, sand then paint yippe!!" Have to take your time to make sure body lines are right, and then the sanding is the most time consuming part, getting a nice even surface accross the bumper. If you dont get it right it will show big time in the reflection of the finished paint! Back to the plastic weld thing, I recommend doing both plastic weld AND a two-part urethan adhesive (which is sandable) to aid in the adhesion (and in my case, strengthen the crappy plastic weld job I did). Finished product:
Posts: 191 |
My gf's pre 98 micah is in some bad shape... but it looked good at one time.... Its cracked in a few places... not sure how to go about fixing the carbon fiber....
98.5 SE 2.5L MTX - TruBendz Borla, Green Filter, SVT F/R Bumpers, E1's
95 SE 2.5 MTX - Full SVT Body w/Mirko, GC + Konis, Omp, KKM, SVT pipes, E1's, Paint
Mods/Pics
Posts: 979 |
[sings] "how low can you go, how low can you go" [sings]
Your gf's car is riding at least 4" above groug, I'd hate to hear it go over a speed bump. What is it's suspension setup like?
86+ miles
Posts: 3,637 |
IIRC it has Ground Control's
230.2 WHP @ 6500
237.0 WTR @ 2250
much like your weiner.
