Posts: 1,190 |
alright well my heads are on and the lower engine mount is not....is there a way to grind down the mount to fit between the heads or do the heads have to come off?!
i remember stazi making a post of using the couger mount but i got a quote from ford for $160... and then doing about 45 minutes of grinding .could go to the junk yard again but i would like some input...please
this was not my doing but i am now woring on the car my self...
PLEASE HELP ME GET MY CAR TOGETHER! ITS IN DAYTON OHIO! I need the motor together and in the car so i can DRIVE it! Pleeeeeese!
diamond pistons for 3.0/forsale
#702 of 2150
Posts: 9,065 |
Originally posted by svtProdigy: alright well my heads are on and the lower engine mount is not....is there a way to grind down the mount to fit between the heads or do the heads have to come off?!
45 min to an hour of grinding. Just look at it and grind, then look again, grind, etc etc.
Posts: 1,190 |
i don't have a couger mount though... i have a contour one and was curious if anyone has done it with a contour not couger like stazi has talked about grinding.
#702 of 2150
Posts: 9,065 |
Originally posted by svtProdigy: i don't have a couger mount though... i have a contour one and was curious if anyone has done it with a contour not couger like stazi has talked about grinding.
I did it with a contour mount, the cougar has a little bit less material to grind down. But literally, I do not recall exactly how it looked when it was done. Just do it!
Posts: 1,101 |
I've got a brand new cougar mount if interested
Posts: 1,190 |
Originally posted by mapoftazifoshoĆ¢ā??Ā¢: Originally posted by svtProdigy: i don't have a couger mount though... i have a contour one and was curious if anyone has done it with a contour not couger like stazi has talked about grinding.
did you have to grind off anything off the head? and did you grind any bolt holes off?
#702 of 2150
Posts: 9,065 |
Originally posted by svtProdigy: Originally posted by mapoftazifoshoĆ¢ā??Ā¢: Originally posted by svtProdigy: i don't have a couger mount though... i have a contour one and was curious if anyone has done it with a contour not couger like stazi has talked about grinding.
IIRC I DID have to get a non-ferrous bit and take a smiggen off the left head (if you are looking at the motor from the timing cover side)
Posts: 1,190 |
yeah i saw that...just didn't think it was enough...i though i might have problems on the righ side...
#702 of 2150
Posts: 1,746 |
Originally posted by Todd aRRRRRRRRR.: Way to read the fuggin stickies.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=3L&Number=740593&page=0&view=collapsed&sb=5&o=2&fpart=1
2nd up from bottom. And also in the top sticky. You need 2 long bolts and 2 short bolts. Contour mount will not bolt to the 3L block. Different bolt size. Cougar mount is $32 from Jenkins.
OMG I overlooked something....?!?! That sucks...so technically ALL 3L's in tour Have to have the 01+ Cougar mount...
2000 Contour SVT
SF - #542 of 2150
