Latest response:
Sure you can pull through or back into the water (prefer pulling through) as long as you run "skinnies" on the back. If running street tires, you have to stay out of the waterbox. FWD cars wheel arrangement is backwards to a RWD car. RWD cars run skinnies on the front and may pull through the water.
A RWD car running street tires on the front is prohibited from pulling through the water just like a FWD car. The reasoning behind this is that street tires hold too much water because of the tread and this introduces a problem for everyone. So as long as you get a set of skinnies with your slicks you are OK. TEC.DECT. MATT.
While it obviously makes sense, Milan doesn't have a problem doing otherwise. The only thing Lapeer would need to change is to not put down so much water. The water is only there to get things moving...no one is asking for Lake Lapeer
