Posts: 1,055 |
instead of porting the cylinder heads on an oval port motor to match the lower intake, why not port the top of the lower intake to match a dual port upper?? Or do the bolt holes not line up? I'm trying to get around using a 3L upper without going hybrid, yet still have stock waterpump placement. thanks ,Derek
Derek Johnson
88 TurboTBird 32psi, t3/t4 bb 50trim, megasquirt, 3 bar map, 50lb inj, roller cam w adj. gear, header, 3" downpipe and full exhaust, gutted intake manifolds, spec stg 3
95SE 3L gone
Posts: 5,810 |
Can't port the 3L lower enough to fit because the 3L lower intake is plastic, and it has a smaller cross sectional area than the split port manifolds. The oval port heads have a larger inlet to the heads.
I don't think they are any better than comparably ported split port heads, just cheaper. And of course, they are what are available with a cam driven waterpump.
See My Mods
Posts: 1,055 |
yeah when I did my 95 I did most everything possible, but this is for a firend and is a daily driver that he wants to able to drive on 87 octane if need be, so I'd prefer to stick with hte stock 3L heads for lower compression. grumble looks like i'm using a 3L upper then.
Derek Johnson
95SE 3L gone
Posts: 9,065 |
It's not that bad...just get someone to do the fuel rail and rest is easy.
Posts: 1,055 |
shh aren't you done yet? what is this month 6? lol
Derek Johnson
95SE 3L gone
Posts: 9,065 |
$$ and school is first priority. The car is about 1.5 hours away from me. Gimme a break.
Posts: 1,695 |
Originally posted by MapOfTaziFoShoĆ¢ā??Ā¢: $$ and school is first priority. The car is about 1.5 hours away from me. Gimme a break.
NO
04 Subaru WRX "Eurosport bling bling fast and furious tokyo drift"
"They have diarrhea of the mouth, and constipation of thought"
Posts: 2,097 |
do you need the oval port intake? I have...I'd let it go CHEAP!!!
98 E0 SVT with some stuff
