Posts: 611 |
Anyone have a modded Escape rail for an oval port? I normally work with the Taurus/Sable rails and this one is slightly different. There is a regulator on the line. Should I cut it off and braze the hole over? Can I leave it alone and leave the vacuum off or should I block it off? What do other people's look like? It doesn't look like the fuel has to go through it like the SVT regulator.
1999 3.0L Cougar: 220fwhp and 200tq
2003 VW Passat W8 with 4 Motion AWD
http://www.cardomain.com/ride/300644
PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
Posts: 5,810 |
Hard to say. It could be a spring loaded diaphragm that is designed to equalize pressure during fuel load changes since the system is returnless. If you are cutting it to make it a return style rail, then get rid of it and use a standard regulator setup.
See My Mods
Posts: 197 |
Originally posted by Blackcoog: Anyone have a modded Escape rail for an oval port? I normally work with the Taurus/Sable rails and this one is slightly different. There is a regulator on the line. Should I cut it off and braze the hole over? Can I leave it alone and leave the vacuum off or should I block it off? What do other people's look like? It doesn't look like the fuel has to go through it like the SVT regulator.
IIRC the Escape is a returnless system that has a fuel pressure sensor on the line. I don't think that it is a regulator.
Have fun,
Mike
The ONLY 96 (engine) 3L
Build 'em fast. Spray 'em faster.
ricehatersclub.com
Posts: 5,810 |
I think it has both a transducer and this other diaphragm. I have an escape rail here and there is no wiring coming form it.
See My Mods
Posts: 197 |
Originally posted by warmonger: I think it has both a transducer and this other diaphragm. I have an escape rail here and there is no wiring coming form it.
What year?? I'm simply going off of working on them and am definately not 100%. Just curious.
Mike
ricehatersclub.com
Posts: 1,210 |
I am using an escape fuel rail...
You can easly remove the regulator looking thing... If you look from under it you will see that there is a C clip... Take the c-clip off and you can dismantle it... Then just WELD over the hole thats left
3.0 14.392@97.237 2.302 60ft
OEM 4-bolt LCA's $105 each
Watch me go
