The pre 98' and 2000 up focus heads are different from the VCT heads. The VCT heads have the cam sensor on the wrong camshaft(will cause ignition problems) and also has a sensor located between the shafts next to the timing belt for the VCT. So if you have a VCT car you will have to stay with a vct casting or swap your wiring harness and ecu.
95 Contour, Custom EVO bodykit, 2.0l, PNP Focus head, Stage 2 cams, Je pistons, Eagle rods, 4in1header, 2.5" header back exhaust(complete stainless), D P nitrous, ram air intake, 10mm wires, flamethrower.
