D'oh....I probably should've mentioned that eh?
Ok between that first alignment and the most recent one I did:
-BAT kit: new springs and struts
-New strut bearings (or thrust bearings I believe some people call them)...done same time as BAT kit
-Changed Front end links to new light alloy style ...done maybe 4 months before BAT kit
-Changed both front lower control arms ( I have 2-bolt style)...done approx 2 months ish before BAT kit
Now that I think about it, when I replaced my LCAs up front I took some measurements with a depth gauge, and those center metal sleeves/pins were lower down in the new LCA's compared to the old ones...by like 3mm....I should've written down the measurements.
...But the bushings were still intact in the arm...not ripped completely out.
