Posts: 392 |
I installed a brand new aftermarket HU (Panasonic CQ-C5301U). I did all the wiring and rechecked to be sure, when i tried the radio the left rear speaker doesn't work and used to work before. I checked with me ohmmeter the wires for that speaker and everything is fine, so I assume that wire and spealer are good. Now I think that it's the HU itself, what do you guys think about that issue ?
Nic.
Contour 99 MTX V6 fully loaded, stock with 110000km. Illuminated sunroof switch. About to do the mystique rear dome light conversion with eyeball dome light.
Posts: 3,076 |
do the battery test. pull the head unit and touch a battery to the left rear speaker wires behind the radio. if you hear a mild pop sound from the speaker, the wires are fine.
2000 SVT Black/Tan #1633/2150 (a few mods)
Alpine: CDA-9835, MRV-F540, MRD-M550
PG: TANTRUM-X 6.5 COMP all around.
Some people wear Superman pajamas. Superman wears Chuck Norris pajamas.
CEL currently: Off
Posts: 392 |
Yeah I remember now about this tip, I will do it tomorrow and tell you about it, thanks.
Nic.
Posts: 392 |
CarpePoon: do the battery test. pull the head unit and touch a battery to the left rear speaker wires behind the radio. if you hear a mild pop sound from the speaker, the wires are fine.
I did put a "AA" battery on the 2 wires for the rear left speaker, didn't hear any sounds. My battery was disconnected, but I don't think that will make any differences.
But, as I stated, i had check with an ohmmeter, on the 2 wires, and I don't have an open loop. So how could it be the speaker or the wires?
Nic.
