Posts: 1,860 |
Thought I would throw this out again in case anyone is waiting for them. The price has gone up, but still very reasonable. 2.5 or 3.0 with any compression you would like.
5 sets of pistons/wrist pins = $640
I don't have the price on the rings just yet. I'm guessing they will be somewhere between $80 and $130 a set.
2001 Lincoln LS8
1994 Lexus GS300
Posts: 1,101 |
Chris, would they be able to do a set of 3L pistons that would take a full oval port 3L up to say 11-11.5:1? If so how would they be able to guarantee no interference with the valves?
BTW, I'm just starting my hunt for stuff now as I've decied to keep the SVT since there is nothing else out there in my price range that I want so don't count me in as of yet
Posts: 1,860 |
Yes they can bump up the compression by adding to the dome that is already there on the stock size, possibly making it a flat top. Takes a lot of math to figure out what the final compression would be so I would have to ask. It would make a sweet nitrous set up though if you had the octane to use it.
I talked to Diamond again since last post and got the price down a bit. $606 for a set of 6 with wrist pins. No word on rings as of yet.
2001 Lincoln LS8
1994 Lexus GS300
Posts: 1,238 |
Originally posted by Keyser: I talked to Diamond again since last post and got the price down a bit. $606 for a set of 6 with wrist pins. No word on rings as of yet.
That is cheap! ![](/ubbthreads/images/graemlins/ponder.gif) -tropictour
2000 Contour SVT
Tropic Green
SHO Shop CAI
Bassani
1999 Contour SE
BAT Kit
Learned patience the hard way
Posts: 2,454 |
Make sure to mark me/Eternal One down for a set.
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
Posts: 347 |
Damn... trying not to spend any more $$$ on the car right now, but that sounds good. I would be interested in a set for the 2.5
1996 Mondeo 24v 4-door
twin janspeed stainless pipe
cat by-pass
Phase 2 RS bodykit
16" cosworth alloys
K&N RU3530
SVT TB/UIM/LIM
poly bushings
konis/bat springs/bar
Pioneer
MSDS
Indiglos
P&P heads
2005 Mondeo Zetec Tdci
Posts: 1,101 |
Originally posted by Keyser: Yes they can bump up the compression by adding to the dome that is already there on the stock size, possibly making it a flat top. Takes a lot of math to figure out what the final compression would be so I would have to ask. It would make a sweet nitrous set up though if you had the octane to use it.
Let me know what they say. Right now I'm just waiting on some prices for porting my 3L heads so that's my primary concern. Once I know more about that I'll be able to give you a firm answer
Posts: 1,860 |
Originally posted by Buckshot77: Make sure to mark me/Eternal One down for a set.
Rick
What compression would you like? I'm assuming about 9.5:1 on a S/C set up. With ported combustion chambers that would be like 9.2-3ish :1.
2001 Lincoln LS8
1994 Lexus GS300
Posts: 225 |
Put me down for one set of 2.5 litre pistons with a 10.5:1 compression ratio (if 10.5:1 will work with 91 octane in the Las Vegas heat!). I would like two sets, but I don�t dare suggest that to my wife right now. I will be building this engine with a set of Jesse�s ported & polished heads with 3.0 litre valves & ST220 springs so that will need to be taken into consideration when adjusting the compression ratio on the pistons.
Not that I�m suggesting that $606 isn�t already a great price; but if more than 5 sets of pistons were sold in this group buy would the price get any better? It might make the difference between me buying one set or two.
The Original Owner of 1998 SVT Contour #3384 of 6535,
Toreador Red/Midnight Blue, Assembled September 3rd, 1997
Also the Original Owner of a 1998.5 Contour SE Sport V6 5-speed,
Vibrant White/Greystone Sport Cloth, Assembled August 6th, 1998
Posts: 3,732 |
Originally posted by NVSVT: Put me down for one set of 2.5 litre pistons with a 10.5:1 compression ratio (if 10.5:1 will work with 91 octane in the Las Vegas heat!). I would like two sets, but I don�t dare suggest that to my wife right now. I will be building this engine with a set of Jesse�s ported & polished heads with 3.0 litre valves & ST220 springs so that will need to be taken into consideration when adjusting the compression ratio on the pistons.
if your doing taht much work, might as well do a 3L swap also
Russell
Oval Port 3L Nearly Done
