Posts: 41 |
My rear tires keep wearing to the metal thread just on the inner 2 inches while the rest remains perfectly good tread. Fifth time i've had a flat on the way to or from work...what do I do? Is this the alignment or does it mean something is bent? I haven't hit/run over anything. Would the struts or something cause this? Is this a common thing? I couldn't find anything with the search. All I know is i can't afford to keep buying tires, man.
Keep on rockin in the free world
my politics are simple...mean people suck
if they refuse to evolve: thin the herd
Posts: 1,177 |
Do you get your tires balanced when they're installed ? I think that can affect tire wear. I would also check the entire rear suspension system, including mounts. Do you have abnormal noises from the rear ?
1998.5 T-Red on Midnight Blue SVT
Build Number 5320 of 6535
Posts: 6,910 |
the alignment is off or something is bent
- 95 Mystique LS - Zetec/5spd
Posts: 4 |
sounds to me like your caster/camber are off. Get a wheel alignment and it should fix it, unless something is bent.
1999 Contour SE Sport 24V V-6, MTX-75,Spruce Green,loaded,4 wheel disc,STOCK(4 now).
1990 Ford Mustang GT-Supercharged, H/C/I, 450RWHP/443RWTQ. My Mustang Site
Posts: 41 |
Thanx ya'll. a friend is kickin me down some tires tonight so i'll have my dude check it out tomorrow when he puts the tires on. Now just need to find a cheep alignment place...if nothing is bent/mounts/etc. its always sumthin, jeeze
Posts: 1,505 |
u need an allignment we had a 97 GL and in like a month our tires went bald the rear was worst we took it to firestone they said how can we drive it like that
1999 Ford Contour SE Zetec with 137k miles.
AIM Name: ContourAlf
Yahoo IM: Contour_Freak
Posts: 1,459 |
The only adjustment you can do to the rear wheels is to set the toe. I suspect you have a camber problem, but there is no adjustment for the camber. Now, I maybe wrong on this, but I believe that defective struts will cause a bad camber setting. If so, the struts could be the problem, rather than the toe alignment.
When I bought my mystique, I was having the same problem, and new struts solved the big majority of the problem.
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
Posts: 1,177 |
Could bad mount bushings cause that?? Like letting the struts move a little so that the tires move more the edge.
