Posts: 2,039 |
I've got the 13" Baer kit, and when it rains, it can be downright scary to drive. The brake response is non-existent. I'm thinking that the rotors get a mist of water on them which prevents the pad to grab the rotor properly. It's fine when I brake often (I.E. in heavy traffic) but once I cruise in the rain for a couple miles, I really have to watch my distance and speed. Lord help me if something gets in my way and I have to brake hard... If I do, the car doesn't slow down at all for a sec or so, until the water clears away from the rotor, and the pad grabs it. (fine then, but braking is still not optimal) Any ideas? Bad wheel design that sprays water on the rotors? (Enkei RS5) Bad pads? Shi++y driver? -J
'98 4Runner
Posts: 10,015 |
All of the above. ha ha Oops, I have the official CEG wheels on mt car too!
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 383 |
This is a problem that plagues stock Grand Prix's as well, right down to a T. You should see the complaints about it at the NHTSA website, not to mention the grand prix forums. I'm convinced it's a pad compound issue, because people with anything other than stock brakes or pads just never experience it, and if it was a "wet rotor" issue it would be a more universal problem across more cars and more braking systems, but it isn't.
Slotted rotors are purported to help, but if I were you (and unless someone comes in with a more scientifically sound answer) I'd get a different kind of pad.
Pacific Green '96 Contour LX V6
â??98 GTP, light mods, 14.66/94
Calypso Green '92 Mustang LX coupe, 13.56/101
Crown Autocross Club 1999 Street Tire Champion, 2000/2001/2002 Street Modified Champion
KCR SCCA 2002 Solo II Street Modified Champion
Posts: 10,015 |
Try these they're supposed to big good with moisture:
AUSSIE ENDLINKS $70
Posts: 21,197 |
Do you have carbon fiber pads by chance? Anything KVR? It's pad compound I'm willing to bet.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
b0x @dm1n
b0x @dm1n
Posts: 4,397 |
My bet is that is wet situations you rotors cool off quick and the hard pad compond isn't grabbing.
-Andy
Andy W.
The problem with America is stupidity.
I'm not saying there should be a capital punishment
for stupidity, but why don't we just take the safety
labels off of everything and let the problem solve itself?
Posts: 375 |
that is weird, i have never had that probem with mine, and i have driven in a monsoon!
Alex T.
98.5 Silver Frost CSVT #5510
05 Nissan Frontier Nismo 4x4 6 speed
85 Bronco II 6" lift 302 swap
Posts: 9,872 |
Originally posted by Stazi: Try these they're supposed to big good with moisture:
hahahahahahahahahaha
Posts: 3,570 |
Originally posted by todras: Do you have carbon fiber pads by chance? Anything KVR? It's pad compound I'm willing to bet.
Exactly what I was going to mention. My KVR Carbon Fiber pads did this, EXACTLY as you described. My bendix don't
Posts: 5,143 |
well... here a technique from Drivers ed. I learned about wet brakes. If you keep your foot lightly on the brake... the pads will make a small ammount of friction and dry the discs off fairly quickly... But that can be a hassle in your case... Maybe contact the manufacturer about it?
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
