Modifications >> Wheels & Tires
Pages: 1 | 2 | 3 | 4 | 5 | (show all)
chknhwk
Reged: 03/14/01
Loc: West Norriton, PA
Re: Question on Offset new
#404037 (Re: 1314) 09/13/03 08:22 PM
I'm going to try to keep the same tires I have now: T1-S's. But I really want/need wider tires.
Now owner of 0 SVT's.
my web page
ssmumich00
Reged: 12/11/01
Loc: Hurricane Valley
#404136 (Re: 1314) 09/13/03 11:01 PM
BASTARD!!!!!
Man, you're wider than me. . .
Well, according to my calculations, that's like nearly 5-6mm.
That's MORE than enough clearance. Well, looks like I'll get 235/40's next time around. The SO3's have stopped rubbing thus far, as long as I don't turn like a nut case on bumpy roads with lots of people in my car.
Life is good.
New Ride
1314Moderator
Reged: 02/24/01
Loc: Houston, TX
#405013 (Re: ssmumich00) 09/15/03 02:29 AM
Originally posted by ssmumich00:
BASTARD!!!!!
Life is good.
If you do, then I'm trying 245's. I will not be beat . Now that your fenders are rolled (I saw your pics. Looks great. I need to see it in person now.), you should do fine with 235's.
1999 SVT Contour
2003 Honda Pilot
2005 Toyota Tundra
RoadRunner
Reged: 03/11/01
Loc: Westchester Co., NY, USA
#405856 (Re: Fmr12B) 09/16/03 02:21 AM
Okay,
Here is what I tried and I got rubbing on the Left Rear Fender.
I got a set of Wheel Max Exel V8 Gunmetal wheels.
17 x 7.0 with a 39 offset, with a set of Wanli S-1099 215/45ZR17.
It rubs only on the outer edge of the tire, and it is cutting into the tread.
I've got to do something about this fender before it cuts the tire down.
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
1314Moderator
Reged: 02/24/01
Loc: Houston, TX
#405882 (Re: RoadRunner) 09/16/03 02:43 AM
Man, sorry to hear that. I guess you'll be rolling your fenders. I wonder why rubbing usually only occurs on one side of the car.
1999 SVT Contour
2003 Honda Pilot
2005 Toyota Tundra
ssmumich00
Reged: 12/11/01
#406007 (Re: 1314) 09/16/03 05:30 AM
39mm offset? with 7 inch wide wheels, the 45 series is too fat. I've figured it out finally.
17X7 will rub with 215's unless your offset is 42mm or greater. Don't try 215/40, that's stupid. 215/45 is min.
17X7.5 will rub if you're 225/45's, BUT WON't with 235/40's, nor with 215/45's with ANY offset (since the extra .5inches stretches the tire out).
I haven't compiled my 18incher list yet. This should be part of the FAQ.
Isneo, write us a code: Will I rub with ___________
(Run fancy ssmumich00 algorithm) , and you stand good chance or probably not (like a magic 8 ball). . .
New Ride
chknhwk
Reged: 03/14/01
#406143 (Re: ssmumich00) 09/16/03 02:36 PM
STICKY, PLEASE!!!!!
my web page
1314Moderator
Reged: 02/24/01
Loc: Houston, TX
#406150 (Re: ssmumich00) 09/16/03 02:47 PM
Still not all true. I never rubbed with my RS5's (17x7, 40mm) or my Attacks (17x7.5, 45mm) and I used the same 215/45 tire on both.
1999 SVT Contour
2003 Honda Pilot
2005 Toyota Tundra
chknhwk
Reged: 03/14/01
#406159 (Re: 1314) 09/16/03 02:57 PM
Thanks for stickying!! Excellent information - I can't wait to get my 17x7.5's!!
my web page
1314Moderator
Reged: 02/24/01
Loc: Houston, TX
#406717 (Re: chknhwk) 09/17/03 02:11 AM
With 235's?
Will you be ordering your tires with the wheels, or getting them seperate? If you plan on buying the tires locally (Discount Tire, etc.) I have a suggestion. Go and talk to one of the sales people, preferrable an asst. manager or higher. Tell him what size wheels you have and that you know of other people who have been able to fit 235's and you want to also. Tell him that after the tires are mounted, you would like to drive around the block a couple of times and if you encounter any rub, you'd like to return the tires for a smaller (225's ?) size or different brand.
Basically, that's what I told the guy at my nearest Discount. The guy had no problem at all with that. He actually told me that he'd let me drive for a day to feel them out. But, I ended up going to a friend of my brothers at a different location. He also said that if I had any rubbing problems, he'd replace them.
1999 SVT Contour
2003 Honda Pilot
2005 Toyota Tundra
Moderator:  1314
Generated in 0.02 seconds in which 0.014 seconds were spent on a total of 14 queries. Zlib compression enabled.
