Modifications >> Wheels & Tires
Pages: 1 | 2 | 3 | 4 | 5 | (show all)
1314Moderator
Reged: 02/24/01
Loc: Houston, TX
FAQ
#322090 - 06/19/03 02:47 AM
I'd appreciate any help here. Just add what you think is a common question. I'll start with the easiest .
Our bolt pattern is 4 x 108.
1999 SVT Contour
2003 Honda Pilot
2005 Toyota Tundra
RogerB
Reged: 10/21/00
Loc: Wichita, KS
Re: FAQ new
#322367 (Re: 1314) 06/19/03 12:01 PM
Stock offset (49.5mm, IIRC)
Acceptable offsets for aftermarket wheels...(38-43?)
Recommended tire specs for various rim diameters...
Stock wheel weights (approx.)
Early SE 7-spoke: 19 lbs
E0 SVT (Cosworth): 20.5
E1 SVT (Cobra): 19.5
Function before fashion.
'96 Contour SE
Edited by RogerB (06/19/03 12:02 PM)
MotorCity
Reged: 09/13/02
Loc: USA
Re: FAQ new
#322379 (Re: 1314) 06/19/03 12:23 PM
What other cars use 4x108 pattern?
"Cobb - It's not just for corn anymore!"
path914
Reged: 08/24/02
Loc: San Francisco, CA
Re: FAQ new
#322385 (Re: MotorCity) 06/19/03 12:33 PM
Old Audi's and Ford Focus's. That's all I know of.
1999 Blk/Tan CSVT #654 - SOLD
2003 Suzuki SV650s
MotorCity
Reged: 09/13/02
Loc: USA
Re: FAQ new
#322441 (Re: path914) 06/19/03 01:56 PM
Lol. I was just putting out a question for the FAQ.
I think the newest Cougars had the same pattern as well.
RogerB
Reged: 10/21/00
Loc: Wichita, KS
Re: FAQ new
#325091 (Re: RogerB) 06/22/03 01:55 AM
Correction/addition:
Stock offset for the early 7-spokes is 47.5mm (as stamped on the back.)
'96 Contour SE
kerrychin
Reged: 07/24/00
Loc: Victoria, BC, Canada
Re: FAQ new
#326318 (Re: RogerB) 06/23/03 03:55 PM
How about:
- Will 225/50 fit stock rims without rubbing (YES!)
- Does 225/50 throw off the speedo noticeably (NO!)
- What are popular upgrade sizes for stock rims because 215/50 is so hard to find (205/55, 225/50, 225/45)
- What are some of the popular replacement tires at each price point?
- If I replace my KDWs with all-season tires, will I notice the difference? (YES!)
99 SVT Contour Silver Frost, #365/2760, DMD
98 Audi A4 2.8 Quattro Tiptronic, 30V -- SOLD!
91 Isuzu Impulse XS Kammback, Handling By Lotus
GTO Pete
Reged: 04/07/01
Loc: Rockville, Maryland
Re: FAQ new
#330315 (Re: 1314) 06/26/03 08:25 PM
Use the SEARCH
With stock suspension:
17s will fit with no rubbing
18s will fit with possiblity of rubbing
19s will fit with possiblity of rubbing
With aftermarket drop:
17s should fit with no rubbing
18s will fit with better chance of rubbing
19s will fit with better chance of rubbing
AFAIK, no one on CEG has 20s or larger.
~ Toque your wheels to ~90 ft/lbs with a torque wrench.
(I do all wheels once in the air, and repeat with all on the ground)
~ Treat your wheels as you would treat your paint.
~ Try to avoid wheel cleaners with harsh abrasives.
~ Wax your wheels.
~ If a wheel is not available in our offset, try contacting the manufacturer to get blanks and have them custom drilled.
You can buy wheels:
www.tirerack.com
www.discounttiredirect.com
www.superbuytires.com
www.whalentire.com
www.wheelmax.com
www.tires.com
www.victoriatire.com
www.atlanticwheels.com
www.azcwheels.com
www.rimstop.com
www.1010tires.com
www.thedealonwheels.com
Capitol CEG Classifieds
Make an offer!
2005 GTO IBM - 337hp/336tq
chknhwk
Reged: 03/14/01
Loc: West Norriton, PA
Re: FAQ new
#332765 (Re: GTO Pete) 06/28/03 11:24 PM
Benefits (if any) of running 7.5" vs. 7" on 17's, 18's so on and different offsets the different width wheels that should be run.
Thought that might want to be addressed as well...
Now owner of 0 SVT's.
my web page
SteveLuoma
Newbie
Reged: 07/17/03
Re: FAQ new
#351384 (Re: 1314) 07/17/03 11:02 AM
What is the stock rim diameter for available year & package (GL/LX/SE/SVT)?
Moderator:  1314
Generated in 0.027 seconds in which 0.014 seconds were spent on a total of 14 queries. Zlib compression enabled.
