Modifications >> Duratec Maintenance
Pages: 1 | 2 | 3 | 4 | 5 | 6 | (show all)
RoadiJeff
Reged: 11/07/02
Loc: St. Louis, MO
Re: Duratec 2.5L Rebuild PIctures new
#803434 (Re: btrautman) 12/27/04 05:03 AM
Sensitive process comes on reassembly the bottom half....using silcone sealant
You sure about the silicone? I rebuilt a motorcycle engine many years ago and the pro shop where I took the head to be ported and polished said to never use silicone. He said that when you put the two halves together some of it can ooze out between the joint. Then if that breaks loose in your engine it can eventually clog up oil ports and cause big problems.
I think I used some 3M yellow sealant or something that he suggested. He said if pieces of it came loose the oil would dissolve it. I didn't had any oil leaks with it for the 5 years I kept it after the rebuild.
The Digital Slacker
Reged: 09/06/02
Loc: Lancaster, PA
#803484 (Re: RoadiJeff) 12/27/04 06:38 AM
Thank you vert much for that picture tour of the engine. I have nothing wrong with my engine, but after looking at all those pictures I want to take it apart. Hope you don't mind, but I just saved this entire thread to a pdf document to review later if I ever do have to take it apart. Again, thank you... =)
btrautman
Reged: 11/13/01
Loc: Austin, TX.
#803507 (Re: F111D F) 12/27/04 07:22 AM
Originally posted by F111D F:
I didn't notice anything in the previous, are you a mechanic or naturally you can do anything you touch?
I recently changed the front struts on my 98 with help from cousin at a transimision shop. they have an air tool that has the ability to switch to hammer only. I had no idea how to use but it call in handy for pushing the struts out of the casting and assisted the axle in and out of bearing and several other manuvers it made quick/painless!
But then they do that on a daily basis removing and installing transmissions.
Paul
Oh did you have to replace the HLA's? I guess that's what they are called hydraulic lash adjusters for the valves?
TNX
I'm not a mechanic. Economic necessity does wonders to motivate one to learn!!!!! Power tools are nice.........
After inspecting the lifters, etc. I didn't really need to replace them....
Regards,
Bob
An ounce of prevention provides a pound of cure!
btrautman
Reged: 11/13/01
Loc: Austin, TX.
#803508 (Re: RoadiJeff) 12/27/04 07:25 AM
Factory recommendations are to use black silicone. Instructions call for wiping down the inside of block for any silicone the squeezes out from compression. this keeps chunks of it from forming and falling out and clogging the oil pickup tube.
Regards,
Bob
btrautman
Reged: 11/13/01
Loc: Austin, TX.
#803509 (Re: The Digital Slacker) 12/27/04 07:26 AM
Your welcome! Glad to see you find it usefull
Regards,
Bob
btrautman
Reged: 11/13/01
Loc: Austin, TX.
#1018961 (Re: btrautman) 08/06/05 11:00 PM
Update, 20k on engine and atx and all is running great!
Bob
MapOfTaziFoSho
Reged: 09/01/02
Loc: The E.L.
#1019649 (Re: btrautman) 08/08/05 03:47 AM
This should be stickied.
Born again on 04/09/06
FOR SALE:
Moonroof glass and motor MB sunshade
PM ME!
btrautman
Reged: 11/13/01
Loc: Austin, TX.
#1019656 (Re: MapOfTaziFoSho) 08/08/05 03:55 AM
I sent SVTPete an email about your suggestion.......never thought about it until you mention it.
Thanks,
Bob
RayModerator
Reged: 07/10/01
Loc: San Antonio/Austin, TX
#1019673 (Re: btrautman) 08/08/05 04:09 AM
There you go, and I agree.. it should be. I will leave it stickied until I hear otherwise from someone who says it shouldn't be (Pete, etc)
Ray
'99 CSVT - Silver #222/276
btrautman
Reged: 11/13/01
Loc: Austin, TX.
#1022354 (Re: Ray) 08/11/05 05:08 AM
Thanks Ray!
Bob
Moderator:  Lance Kinley, GTO Pete, Ray
Generated in 0.021 seconds in which 0.016 seconds were spent on a total of 14 queries. Zlib compression enabled.
