Pages: 1
Bounty Hunter
Reged: 01/23/01
Loc: Brampton, Ontario, Canada
ZETEC PROBLEMS
#20736 - 09/05/02 11:29 PM
I have a 96 ZETEC, it has about 145,000 kms on it. I'm having a strange problem with it. When I hit the gas, I hear, sounds like a pssssst sound, b4 the car will go anywhere. When it does that, half the time the car stalls out. Plus when I'm driving, sometimes my car will strugle to catch upto traffic. You can hear the car struggling and when it's shifts, it shifts really hard. I know its not the transmission cause I just replaced it and it was doing it b4 I replaced the tranny. Can anybody help me out?
THANKS
Dion
1995 Ford Mustang GT
Magnaflow Exaust
Clear Corners
BBK Cold Air Intake
MSD Ignition
Alpine Security System
2 12' Alpine Type S Subs in Alpine Box
Sony 1100W Mono Amp
JVC CD/WMA/MP3 Deck
Sold!!!
1996 Ford Contour GL
Stolon #05
Reged: 08/30/01
Loc: Ok City, OK
Re: ZETEC PROBLEMS new
#20808 (Re: Bounty Hunter) 09/06/02 12:47 AM
I'm starting to notice a similar problem, on mine, it's a 97. Same thing, step on the gas, hear a psssst sound and the car tries to studder and wants to die sometimes, then will pick up and go and be fine. Will do it every so often and then it's all fine for a long time and then will start acting up again. But mines never shifted hard like you are saying yours is... I have been wondering myself what it could be... Don't know if I need to have the pcv valve replaced as it's never been done or if it's the egr valve starting to get clogged. I'm not getting any cel's or codes when I hook into the obd-II scanner so I don't know what's going on.
ExDelayed
Reged: 05/31/00
Loc: Ogden, UT
#20857 (Re: Stolon #05) 09/06/02 01:30 AM
I've seen the hard shifting problem firsthand. It will usually do it when I am at full throttle and let off right before it would do the 1-2 shift. I have had it do it before and it made a little chirp and some torque steer. It was very cool, but I was thinking *aah! motor mounts!* when it did it. IIRC, there is a TSB out for it.
I had my car studder free for about a week. I changed the plug wires and reset the computer. Then it slowly came back.
Jon Miconi
Coming Soon!
01 Cougar
98 V70R
GeoPappas
Reged: 12/13/01
Loc: Northern VA
#20901 (Re: Bounty Hunter) 09/06/02 02:09 AM
Sounds like it might be a vacuum leak.
Where does the sound emanate from? Please be specific.
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
SVT SNOB
Reged: 07/17/01
Loc: Burlington, ON
#21869 (Re: Bounty Hunter) 09/06/02 11:38 PM
My 98 is doing the exact same thing I thought it was because my air mixture was getting to lean, and my cat was clogged. Yesterday as I was slowing down the car started to lurching ( as if someone relesed the cluth too fast but my car isn't MTX) then when I steped on the gas the car lagged then all of a sudden took off. I'm also wondering if it's my computer becasue sometime when I goto accelerate from a standstill the car will lag upto 2500 RPM hten it will just accelrate upto 6000RPM and I wont even be flooring it.
AKA NVS SVT
98.5 Silver/Blue SVT#4553
Yeah it's modded
98 T-Red/Blue SVT Contour Totaled 06/05/06
03 3L,VCN 2000,CAT Cams,MSDS Headers w/Y-Pipe,XCal2 and lots more
Pages: 1
0 registered and 54 anonymous users are browsing this forum.
Generated in 0.076 seconds in which 0.071 seconds were spent on a total of 14 queries. Zlib compression enabled.
