Pages: 1 | 2 | (show all)
projectSHO89
Reged: 09/19/02
Loc: St. Louis, MO
Re: a/c wiring issues 98 se new
#1312565 (Re: Tony2005) 09/05/06 12:30 PM
If the pin for the Violet/Orange wire at the Blower Switch end (or the internal on-off for that pin) should fail, it could also cause a no A/C condition.
There is no VI/OG wire on the Blower switch. That wire is on the MODE switch and should be hot in all switch positions except OFF while the ignition switch is in RUN. It is the wire that supplies feed to the cycling switch circuit and, ironically, is also switched by the A/C coil relay to energize the coil.
Did I mention that the symptom is ill-defined? Until he clarifies what the actual fault is, we can only guess what works or doesn't since the OP did not describe the actual fault very well.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
0 registered and 4 anonymous users are browsing this forum.
Generated in 0.081 seconds in which 0.074 seconds were spent on a total of 14 queries. Zlib compression enabled.
