Pages: 1
cashewnuts
Newbie
Reged: 08/04/06
CD43 ( Insight & questions)...
#1308718 - 08/29/06 06:30 PM
car: '96 GL 2L auto.
problem: o/d light flash, shift bang
*(thanks for all the help I have received from this forum)
CD43 Ford called "Batavia"
Had problems early on...1994...when used with Ford Probes.
If you want to be enlightened see TSB 93-18-10
DTC codes: use EEC IV test connector, not MECS connector
(which one located under dash?..and location of the other?)
TFT--Transmission Fluid Temp.Sensor.
(anyone hear of problems with that sensor?)
(If you turn the o/d off) would it be ok to drive in the 3rd gear at 55mph?
See o/d light flashing..but no check engine light. Why?
Don't the DTC codes and CEL codes work together? For example, bad torque converter codes are P1741 to P1744.
Ford said I may have a bad T.C...but I never saw a check engine light.
thanks..
Re: CD43 ( Insight & questions)... new
#1308947 (Re: cashewnuts) 08/30/06 12:49 AM
Read your previous thread .
The part number is in this thread.
If you are looking for a magical solution without doing anything, try sending a PM to F111D F. In this thread , he mentioned that he owned a magic rubber mallet.
SquareHead
Reged: 11/29/05
Loc: Winnipeg, Canada
#1310122 (Re: Tony2005) 08/31/06 05:28 PM
The O/D light flash tells a trans fault is happening.
Take it to a reputable Trans shop and have it scanned. Don't guess at it. Too expensive. Check your last post as well there are replies there.
95 Contour GL. Bought new.
BAT Sway Bars/Pioneer CD/Koni Rear Struts/Mobil Fluids.
Looking for 15" alloy rims-PM me.
180,500km's so far.
Pages: 1
0 registered and 48 anonymous users are browsing this forum.
Generated in 0.076 seconds in which 0.071 seconds were spent on a total of 14 queries. Zlib compression enabled.
