Pages: 1 | 2 | >> (show all)
F111D F
Reged: 05/27/00
Loc: Lucas,Ohio
Re: blower switch, runs high then quits new
#1310797 (Re: 96SEBlack) 09/01/06 04:36 PM
Yes this is not common, as others have said
How's your electrical abilities ie using an ohm meter?
With out removing (because the radio has to pulled the console removed the access the two screw on the bottom of the center trim panel before it can be removed)
To test blower switch on high unplug the connector at the blower motor check continuity/resistance from the BK/Rd (on the removed connector and the other test lead to good ground metal frame under the dash. Also unplug the connector at the resistor pack.
Reading should be the same as shorting the two test leads together. Meter on x-1 or lowest scale.
Do you smell a hot burnt smell when you run the blower for 20 secs emanating from the switch area?
The blower motor and the resistor pack uses the ground same connection. I notice the blower relay also uses that same ground point? That ground is located bottom of the RH door pillar. I doubt that problem many other circuits use that same ground. When is comes to heavy current draw the condition of the contacts on the switch and the relay K-14 shows up. Swap relay with a like one in the CJB under the dash. The relay above is the rear window defrost and one below is the wipers.
I"m using the 98 wiring schematic and don't have a 96 although the before 3/98 should be the same.
I just hate to remove interior trim pieces some clip usually breaks and HELLO rattles and squeaks.
Paul
I'll check back later once I take care a few honey-dos!
Paul
96SEBlack
Newbie
Reged: 10/21/03
#1311086 (Re: F111D F) 09/02/06 03:27 AM
Thanks for all your suggestions!! I've been hesistant to remove too many parts during the week since this is my daily driver for work. I will tear into it this weekend and see what I can find.
Using a multimeter is not a problem and there isn't any burning smell when the switch cuts out after 20sec to 1min.
I'll post back and let you know what I find.
96SEBlack
Newbie
Reged: 10/21/03
#1311376 (Re: 96SEBlack) 09/02/06 10:07 PM
I swapped the two yellow relays R13 (rear defroster) and R14 (blower motor). That didn't help.
I got to the switch, finally and found black/charred/melted plastic at the connector. The switch itself doesn't look as bad, but it has melted plastic also.
Is the switch and connector separate part numbers or does the switch come with a connector?
It looks like the 4 wires from the switch go to the resistor. Is there a Ford part number for these wires with connectors already attached at both ends? I doubt it, but I thought I would ask anyway.
Is the switch/connector just a weak component that went bad or is there something else that may have caused the switch to burn out like that?
Thanks for your help!!
Con-Man
Reged: 03/12/05
Loc: ClarksVegas
#1311417 (Re: 96SEBlack) 09/02/06 11:38 PM
I had the same problem my blower was running on high for a long time then one day it just quit working. My connector was melted, I called the dealership and they wanted to charge me $29.00 for the connector. I decided to hit the savage yard I was very lucky I found a connector that was not damage. I took it off the car went to pay for it the lady that owned the salvage yard told me just take it no charge so I guess free beats $29.00.Installed the new connector blower operates on all three speeds. I'm glad the heat problem is fixed I must get the Tour ready for the winter and the snow. The Tour is our go to car in the snow the front wheel drive is awesome in the snow
2006 Mustang GT
2004 Mustang GT (Gone)
2004 Yamaha FZ1
1995 Contour GL
1982 Cutlass 2 door
FavoriteMystaque
Reged: 10/17/04
#1311445 (Re: Con-Man) 09/03/06 12:31 AM
I think the new connector (solder/shrinktube splice) does come with the switch, you could try just the switch to see if it works OK. I replaced the switch in my sister's Mystique, and did not do any wiring.
projectSHO89
Reged: 09/19/02
Loc: St. Louis, MO
#1311683 (Re: 96SEBlack) 09/03/06 02:44 PM
BTW, if you're still within the 150K and 10 years (from in-service date), this is a covered repair under Owner Notification Program 01M07. Being a 96, you may have already passed the cutoff.
If you have to do it yourself, obtain Blower Switch Connector Repair Kit #F5RZ-14A411-AA (Less than $25) and perform the repair yourself.
Performing a SEARCH for "01M07" will yield quite a few relevent posts going back several years.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
0 registered and 19 anonymous users are browsing this forum.
Generated in 0.073 seconds in which 0.068 seconds were spent on a total of 14 queries. Zlib compression enabled.
