Pages: 1
NiggShevik
Reged: 04/26/05
Narrowed problem down--help
#1306417 - 08/25/06 03:29 PM
Hello everybody,
So, vacuum leak...
What i've done:
-Replaces upper/lower intake gaskets three times
- plugged in o2 sensor that was unplugged...(CEL OFF permanently since i plugged this in.. still stalls)
I think it is a simple idle problem but i wouldn't really know.. i think this because:
-AC (when on)keeps car from stalling when i come to a stop
-If i am gentle, and give it some gas at a stop, idle balances out
-If i come to a harder stop, engine tends to stall
- Seems to want to stall more under hot conditions
-CEL OFF since plugged in 02 sensor, had been on for months before that
What do you guys make of this? Is it a small idle problem, or something else?
2000 Black SVT Contour
SquareHead
Reged: 11/29/05
Loc: Winnipeg, Canada
Re: Narrowed problem down--help new
#1306915 (Re: NiggShevik) 08/26/06 01:42 PM
Try cleaning or replacing the IAC valve. Insure none of the vacuum lines have cracks. I replaced all mine as they cost little. How is the PCV line and valve? It is a natorious culprit for cracking.
95 Contour GL. Bought new.
BAT Sway Bars/Pioneer CD/Koni Rear Struts/Mobil Fluids.
Looking for 15" alloy rims-PM me.
180,500km's so far.
NiggShevik
Reged: 04/26/05
#1306955 (Re: SquareHead) 08/26/06 04:57 PM
I will do all the IAC stuff, i actually have a pcv valve i can replace the old one with. I'll try that out. I really hope it's something that simple. Thanks for your help
Pages: 1
0 registered and 13 anonymous users are browsing this forum.
Generated in 0.07 seconds in which 0.064 seconds were spent on a total of 14 queries. Zlib compression enabled.
