Re: Major wiring issues please help new
#1303332 (Re: icysvt) 08/19/06 06:02 PM
Check VSS, connector and wiring from connector to PCM.
From Autozone
icysvt
Reged: 12/17/05
Loc: tennessee
#1303334 (Re: Tony2005) 08/19/06 06:11 PM
From Autozone
Ah ha is that in the top of the tranny if it is. that is the one plug on my new harness thatdid not match up and i had to splice my old plug in to my new harness and i bet i crossed the wires
1998 CSVT #844 Born May 9,1997 Silver n Blue
B&M Short throw shifter
Eibach springs
4 Memphis PR 12"
www.cardomain.com/ride/2273778
#1303336 (Re: icysvt) 08/19/06 06:13 PM
From Autozone
Ah ha is that in the top of the tranny .......
Correct.
icysvt
Reged: 12/17/05
Loc: tennessee
#1303337 (Re: Tony2005) 08/19/06 06:15 PM
From Autozone
Correct.
ok if i did cross those I didn't possibly hurt that did I
Eibach springs
4 Memphis PR 12"
#1303338 (Re: icysvt) 08/19/06 06:17 PM
Only one way to know. Put it back correctly.
Edit.
For the 1998/1999 SVT, VSS signal is Pin 58 on the PCM connector. And that wire should be White/Violet.
Edited by Tony2005 (08/19/06 06:25 PM)
icysvt
Reged: 12/17/05
Loc: tennessee
#1303340 (Re: Tony2005) 08/19/06 06:20 PM
Only one way to know. Put it back but wait while I look through the PCM wiring.
ok the old harness had that plug cut and spliced in on it also but the wires weren't the same colors on the new harness so i kinda guessed. I wasn't sure what that was for til now
Eibach springs
4 Memphis PR 12"
#1303342 (Re: icysvt) 08/19/06 06:32 PM
If the old VSS has a tell tale sign of Green/Red wire, then it was from an early 1995 and won't work for you. You will need a new VSS and connector (if you threw away the connector from your SVT when you spliced it) .
Note that the signal should be 0 mph:0 hertz, and 55 mph:125 hertz
icysvt
Reged: 12/17/05
Loc: tennessee
#1303343 (Re: Tony2005) 08/19/06 06:38 PM
well the car had one spliced on the old harness also. the wires on it are red and white but the wires on the harnesses are all purple with a colored stripe
Eibach springs
4 Memphis PR 12"
icysvt
Reged: 12/17/05
Loc: tennessee
#1303345 (Re: icysvt) 08/19/06 06:47 PM
oh and the plug i took off the harness was a wide 4 wire plug with the metal clip that locks it on but with only 2 wires in it. the one to the vss was small and curved on one side i think but looked nothing like the one that hooks to it
Eibach springs
4 Memphis PR 12"
icysvt
Reged: 12/17/05
Loc: tennessee
#1303416 (Re: icysvt) 08/20/06 01:02 AM
ok i took and changed the wires and still nothing. is there a fuse for the vss or do i just need to get a new one?? worked fine before. the wires i have are violet and yellow and violet and black. So IDK???
Eibach springs
4 Memphis PR 12"
0 registered and 19 anonymous users are browsing this forum.
Generated in 0.097 seconds in which 0.091 seconds were spent on a total of 14 queries. Zlib compression enabled.
