Pages: 1 | 2 | (show all)
GilNewball
Reged: 11/09/05
Loc: Lake Worthless, Flori-DUH
The wackiest car Ford ever put out...
#1299804 - 08/13/06 11:03 PM
It just so happens to be my Contour.
Well, I replaced the alternator. I also replaced the links between the stabilizer bar and the struts for both sides, and I also did my first brake job. Well, when I pulled it out to test drive it, it was misfiring one one cylinder. At the higher RPMs, it felt much smoother.
When taking off of one cylinder, the car would kinda hesitate when accelerating. It would move then the engine would stop, the go again, all of that occuring within a second.
Well, I went on, and the car suddenly stopped. It died. At the middle of an intersection. At the opposite side of the freeway onramp. Yes, when they say that cars break down at the worst possible places, it is true. It is VERY true.
Well, I tried starting it several times, and the engine turned on (still misfiring on one cyl), and after a few seconds, it would go down to only one cylinder firing, and then it'd quit.
Did I miss a step in my jaunt worth of repairs? I did everything to the letter.
This time, I really do need help.
Is my car for sale? PM me if you're in South FL.
Originally posted by XKontour98:
Haha that's awesome! Go GM!
YES, SIR!!!
General Aviation is Looking good right now...http://www.beapilot.com
Re: The wackiest car Ford ever put out... new
#1299808 (Re: GilNewball) 08/13/06 11:09 PM
Was the CEL flashing when it was misfiring? Scan for CEL codes and post. Are you sure you reinstalled all the wirng back properly when you did the alternator?
GilNewball
Reged: 11/09/05
#1299811 (Re: Tony2005) 08/13/06 11:18 PM
No lights were flashing at all (at least, I didn't notice). I will need to check for codes.
The alternator was installed correctly.
The thing now is that the car won't start. I managed to get it coasting (with a friend of mine who just so happened to see me stranded in the middle of the road). It was towed back to my place, and it's sitting in the driveway.
This time, I am really contemplating to get rid of it. I'm still thinking over it, but it's not a question of "if" but "when" it's leaving.
YES, SIR!!!
FavoriteMystaque
Reged: 10/17/04
#1299844 (Re: GilNewball) 08/14/06 12:41 AM
How old is the battery? Try recharging it, then check voltage is about 14 or above IF the car starts.
Tisby
Reged: 06/14/04
Loc: SBN
#1300004 (Re: FavoriteMystaque) 08/14/06 05:36 AM
I'm thinking that despite thinking that you installed the alternator correctly, you didn't. It seems like the car was running off the battery and when it drained - car died. Either that or you got a POS alternator. I wouldn't ditch the car just yet...
2000 Mystique LS
Duratec 2.5L MTX
GilNewball
Reged: 11/09/05
#1300192 (Re: Tisby) 08/14/06 04:06 PM
Well, I am still able to get the starter going. The battery is fine. The battery light never turned on. I kept cranking and cranking it, but it just wouldn't start.
The battery is fairly new (got it earlier this year). It was recharged a couple of weeks ago, prior to replacing the alternator (that's when I decided to replace the alt. It ran down the battery).
I'm really lost now. I might take it to the dealer to diagnose it, but that's after I exhaust the resources here in the forum.
YES, SIR!!!
FavoriteMystaque
Reged: 10/17/04
#1300482 (Re: GilNewball) 08/14/06 11:14 PM
I have a few more ideas (work is slow tonite )Check for fuel pressure, should be 30-40psi. Fuel pump might have quit, or the fuel pump safety reset button (above the driver side kickpanel) needs a push. It is also possible you flooded the engine with gas, and the cylinders have lost compression temporarily. Try starting with gas pedal down while cranking, release it if it catches. Also, scan for codes with your OBD scanner (relatively affordable at Advance Auto parts) Maybe some other CEG'ers can contribute their experiences..
GilNewball
Reged: 11/09/05
#1300910 (Re: FavoriteMystaque) 08/15/06 03:00 PM
Well, I'll check those out.
But for more info: The car was running for about 15 minutes prior to taking a dump on the on-ramp. The fuel pump was running consequently when I tried starting the engine again. And it did fire away a couple of times before dying once more a few seconds afterward.
YES, SIR!!!
GilNewball
Reged: 11/09/05
#1302117 (Re: GilNewball) 08/17/06 03:52 AM
OK, just a recap...
Car died on the road after running fine for 7.4 miles. Battery is still charged. Engine will not fire. Fuel pump works. No CELs. Codes are still a possibility.
Any other ideas? I am in great need of help here.
YES, SIR!!!
#1302121 (Re: GilNewball) 08/17/06 03:54 AM
Originally posted by GilNewball:
... Engine will not fire....
Does it crank (turn over)? Normal sounding crank or fast crank (as in no compression crank)?
GilNewball
Reged: 11/09/05
#1302125 (Re: Tony2005) 08/17/06 03:58 AM
Normal crank.
YES, SIR!!!
#1302135 (Re: GilNewball) 08/17/06 04:09 AM
Check battery terminals, wires to starter, crank and camshaft position sensors/connectors.
Vetterin
Reged: 11/05/02
Loc: Alsip, (Chitown) IL
#1302511 (Re: GilNewball) 08/17/06 06:57 PM
Try checking your camshaft/crankshaft position sensor.
Bruce O
98.5 SE Sport MTX, KKM, SVT exhaust
85 Z51 Vette stroker (just in case)
Never forgetting the "Old Fart" Ray
GilNewball
Reged: 11/09/05
#1302651 (Re: Tony2005) 08/18/06 12:23 AM
Those were fine. And they still are.
And as far as the cam/crank sensor, the car was running fine for about 15 minutes before suddenly quitting. And it was quite sudden.
It's odd, I know.
Can you instruct me on where the cam/crank sensor(s) are? I can give them a looksey.
YES, SIR!!!
#1302658 (Re: GilNewball) 08/18/06 12:37 AM
Chongo's link is down
Top sensor
Camshaft Position Sensor CMP from Autozone
Bottom sensor
Crankshaft Position Sensor CKP from Autozone
GilNewball
Reged: 11/09/05
#1302696 (Re: Tony2005) 08/18/06 01:15 AM
Thanks. In the meantime, any other ideas?
YES, SIR!!!
GilNewball
Reged: 11/09/05
#1312380 (Re: GilNewball) 09/05/06 02:05 AM
Any ideas? I'm still stuck. And I am avoiding taking it to the dealer at all costs (and I am just about to).
I tried starting it again, but no go. The start turns, and the engine turns as well, but it won't turn under her own power. Battery is good, and engine seems intact. And I need this car running. At least in sellable condition. It won't be much longer that I'll be with the moneypit car.
I REALLY need help.
YES, SIR!!!
#1312406 (Re: GilNewball) 09/05/06 02:20 AM
Need the CEL codes, Man ....and have you tested the CKP and CMP yet?
0 registered and 2 anonymous users are browsing this forum.
Generated in 0.073 seconds in which 0.067 seconds were spent on a total of 14 queries. Zlib compression enabled.
