Pages: 1 | 2 | (show all)
alaric
Newbie
Reged: 07/21/05
Re: P0455 - Is the Dealer Lying to Me? new
#1285181 (Re: alaric) 07/25/06 02:06 AM
Thank you everyone for the help. I thought i'd provide an update.
I changed the cap and reset the computer by disconnecting the battery (next time i'll try the fuses). So far so good, no CEL, but i did't drive that far. I'll update again after some miles.
The cap now goes on a lot easier. I don't have to fight with it to get it on. I wonder if the old cap has an issue with heat. It started to become a pain last summer, subsided in the fall and became a real pain this summer.
It would wonderful if this new cap fixes the problem. Regardless, i will certainly attempt more repairs myself.
#1285188 (Re: alaric) 07/25/06 02:13 AM
Good for you. Next time, tell the dealer to refer to this TSB 03-20-3 with the first line stating to check for a loose fuel cap first.
"MANY EVAP LEAKS ARE CAUSED BY A LOOSE OR FAULTY CAP"
http://www.ford-trucks.com/tsb/fulltext/show_article.php?tsb=03-20-3
Ex-Mean'Tour
Reged: 01/26/05
Loc: Massachusetts
#1285787 (Re: LUCA) 07/25/06 06:16 PM
Originally posted by LUCA:
FYI, you can go to AutoZone and have any codes read and erased for free.
Codes pulled yes, but not every store or person will reset them. Some have told me they aren't allowed to, others just did it without even asking!
MUST SELL - ECM computer new for a 98 V6 mtx + pats
Now trolling in a Red Nissan 4 x 4
Big Jim
Reged: 09/03/00
#1311637 (Re: Big Jim) 09/03/06 10:56 AM
This is just a follow up about my tight gas cap. In hot weather the cap would bind so severly that it was very hard to remove or install. Light grease on the threads didn't help much.
I finally replace the cap and that was all that was wrong. I was afraid that I may need to replace the filler neck, but I did not. The problem was fully resolved with a new cap.
Jim Johnson
98 SVT
03 Escape Limited
F111D F
Reged: 05/27/00
Loc: Lucas,Ohio
#1311774 (Re: alaric) 09/03/06 06:49 PM
Evaporative codes are becoming more and more prolific. Especially as the vehicle gets some age. Smoke tests seem to be the only real why to troubleshoot? Not by my experience but by talking to several service managers.
Might be a tool to look into cost of having to pay a dealer is getting so prohibitive while they troubleshoot such a time consuming system. Especially for those of us who try to keep vehicle longer. Alias tight wads
My daughter in-law has 2002 Caravan and I found a TSB where the Evap monitor program may be to sensitive. Dealer needs to reprogram PCM. For the .20 code which I believe is the smallest. New cap did not fix since the original physically came apart. Never seen that before. She was complaining the cap becoming harder and harder to remove so I lube the threaded area.
So now every few weeks I clear code while looking for possible other codes, check all the lines I can find. I see now why the dealers use smoke machines now.
It really be nice if the tubing was stainless steel,routing would be re-engineered, etc. and etc., if this system is so important that absolute integrity be maintained the bean counters need to comply, also? EH?
wonder what how the dealer tested? This wholesale changing out of parts ticks me off. Not cheap either.
I think our 98's only go down .40 not as sensitive as the newer stuff?
Paul
Good luck with yours!
Paul
F111D F
Reged: 05/27/00
Loc: Lucas,Ohio
#1311790 (Re: Big Jim) 09/03/06 07:34 PM
Big Jim any idea how long this site been around and who behind it?
Looks like I need to do some investigating, 2006 Ford CD shows p0442 as the smallest as .40 not .20 as Chyrsler???
I was under the assumption OBD-II codes the evaporative would be all the same as "genertic"? Nothing simple anymore Yeesh!
TNX
Paul
Paul
Edited by F111D F (09/03/06 07:45 PM)
Big Jim
Reged: 09/03/00
#1311902 (Re: F111D F) 09/04/06 01:22 AM
Are you asking about this web site? The Contour Enthusiast Group?
Jim Johnson
98 SVT
03 Escape Limited
#1311907 (Re: Big Jim) 09/04/06 01:28 AM
I think F111D F is asking about this one. www.OBD-codes.com
Originally posted by Big Jim:
A loose gas cap most certainly can cause this code. Follow this link:
http://www.obd-codes.com/trouble_codes/generic/p0455-evaporative-emission-control-system-leak-detected-large.php
This explains why it was started.
http://www.obd-codes.com/about.php
F111D F
Reged: 05/27/00
Loc: Lucas,Ohio
#1312028 (Re: Tony2005) 09/04/06 05:28 AM
Thanks guys! Tony me and my forgetter could use your mind reading abiltity! Or we think alike and that's scary for you. Hi Hi TNX
Paul
Paul
Big Jim
Reged: 09/03/00
#1312129 (Re: Tony2005) 09/04/06 05:34 PM
That was posted so long ago that I had forgotten about it. I found it on a google search. Now that I look back on Tony's comments I realize that it is probably worth bookmarking for future reference. It looks like on of the better OBD II sites.
Jim Johnson
98 SVT
03 Escape Limited
0 registered and 40 anonymous users are browsing this forum.
Generated in 0.08 seconds in which 0.074 seconds were spent on a total of 14 queries. Zlib compression enabled.
