Pages: 1 | 2 | >> (show all)
ToasterOven
Reged: 09/28/05
Loc: Earth. I think...
electrical problems
#1272140 - 07/05/06 03:19 AM
Okay, so i changed my alternator. Thanks Ray for the how-to help. While I was in there i also changed my Bank 1 Sensor 1 O2 sensor to cure a slow sensor response code. The CEL came back on within 20 miles of driving. And now my lights, all them, interior included, flash.the flashing is releveant to engine speed. at idle, no flashing. but as the rpms go up, more flashing. the flashing can be described as a quick dim, less the a half second in length, but contineuousand rapid in pace. turning things on and off does not help, and no way to tell if it flashes when the lights are off. and help on this would be great
99 V6SE Sport ATX
ToasterOven
Reged: 09/28/05
Re: electrical problems new
#1272888 (Re: ToasterOven) 07/06/06 04:03 AM
any one even have a remote idea what is causing this? alot of my driving is at night and it gets really annoying. plus i doubt its good for the car and all.
99 V6SE Sport ATX
vincom
Reged: 11/03/05
#1272944 (Re: ToasterOven) 07/06/06 06:35 AM
that is the strangest thing i have ever heard......are you sure you wired the alt. correctly, or damaged any wires. what code does the cel give
canadian, 98 mystique LS sport 2.5L atx
98 contour se 2.0 L atx
00 300m
#1273085 (Re: ToasterOven) 07/06/06 02:17 PM
Charge the battery well and test the battery and alternator.
Alternator test. Engine running, voltage across battery terminals shold be 14 to 14.5.
ToasterOven
Reged: 09/28/05
#1273423 (Re: vincom) 07/06/06 09:49 PM
not sure, where can i get it scanned? used to do that at school, but im graduated now.i think it will be for the secondaries though. ever sense i changed the spark plugs, secondaries will only open in first gear. something to do with that little box under the engine cover if i recall.
ill try to do the test tonight and see if they reveal anything. all the wires were put on properly, and they were all still bendable when i disconnected them. no cracking or anything. but we'll see.
99 V6SE Sport ATX
ToasterOven
Reged: 09/28/05
#1274374 (Re: ToasterOven) 07/08/06 02:23 PM
the battery checks out fine. engine running(on an analog tester) it was almost touching the 15 mark, no matter how many things i turned on. lights on for one minute, and it read almost 12. but it also read almost 12 immediatly after power down and no lights on. again, it always read almost 12 no matter what i turned on.
thursday night though, i noticed something strange. i was sitting in my car listening to music for anout 10 to 20 minutes with the car off.(after market head unit,sub, amp)
for a few miles after i turned the car on, it seemed to not flash the lights at all. even then on friday and today, it seems to not be flashing the lights as bad. except now i cant tell how fast im going cause the lights lighting up the speedo dont work, and the dimmer switch is stuck except to turn on the dome light.
im very confused as to what this is...
99 V6SE Sport ATX
#1274487 (Re: ToasterOven) 07/08/06 07:43 PM
not sure, where can i get it scanned? ...
Autozone or Advance will scan it for free. Post the exact codes then.
ToasterOven
Reged: 09/28/05
#1275093 (Re: Tony2005) 07/10/06 04:01 AM
funny you should say that, the CEL went off last night and hasn't come back on yet. also, my lights dont seem to be flashing today. guess ill find out when i go home tonight. thanks for the help though!
i called and asked my uncle, who used to be ford tech, and he said it could possibly the headlight or dimmer switch, which he said were somewhat common to burn out on the contours. he also said they were a dealer recall, meaning you complain about and they fix it as a recall, for whatever reason. again, thanks for the help ive been getting thus far, dont know where id be without it.
99 V6SE Sport ATX
#1275267 (Re: ToasterOven) 07/10/06 01:59 PM
...i called and asked my uncle, who used to be ford tech, and he said it could possibly the headlight or dimmer switch, which he said were somewhat common to burn out on the contours. he also said they were a dealer recall, meaning you complain about and they fix it as a recall, for whatever reason. again, thanks for the help ive been getting thus far, dont know where id be without it.
The Headlamp switch recall might have the flickering lights but not the CEL being turned on (and off).
ToasterOven
Reged: 09/28/05
#1275852 (Re: Tony2005) 07/11/06 03:24 AM
yes. earlier though i said it might be the secondaries not opening up after i changed the sparkplugs, i changed the 02 sensor after the plugs and never cleared the codes. and now that the CEL is gone, my secondaries work in all four gears again. so i think thats all it was. are the old codes still stored on the car so i can see what the problem was?
so later this week ill take a drive on into the ford stealership and see if they cant change my switch, or atleast diagnose what really is the problem. thanks for all the help though, ill try to report back my findings when i get them.
99 V6SE Sport ATX
#1275854 (Re: ToasterOven) 07/11/06 03:27 AM
I think the 99 model is not covered under the recall. You may want to register at www.fordvehicles.com (need your VIN) and see if your car is covered before taking a drive out there.
ToasterOven
Reged: 09/28/05
#1275901 (Re: Tony2005) 07/11/06 04:33 AM
well, its not that far away, but i will definetly check! and register... thanks again for the help. its greatly appreciated
99 V6SE Sport ATX
ToasterOven
Reged: 09/28/05
#1297724 (Re: ToasterOven) 08/10/06 06:58 PM
update. still dont know why my lights are flashing or whatever, but i do know why the speedo lights turned off. the dimmer switch curcuit board exploded. new onw on order soon.
second, the CEG left me with codes P0401 EGR insufficient flow. i know how to fix that
and then also P1151 lack of -H02S1 switches lean bank 2 sensor one.
so now what shall i do?
99 V6SE Sport ATX
#1297831 (Re: ToasterOven) 08/10/06 08:37 PM
Did you change the Bank 2 (radiator side) Upper Sensor the last time?
If you did, then per TSB, your EGR could be the issue.
P1151 - Lack of HO2S-21 Switch, Fuel Trim at Limit The HEGO Sensor is monitored for switching. The code will set when the HO2S fails to switch due to circuit or fuel at or exceeding a calibrated limit.
Electrical:
· Short to VPWR or VREF in harness or HO2S
· HO2S circuit shorted to Ground
· Water in harness connector
· Open circuit
· Corrosion or poor mating terminals and wiring
· Damaged HO2S
· Damaged PCM (other DTCs should be present)
Fuel System:
· Excessive fuel pressure (stuck fuel pressure regulator, restricted fuel return lines, etc.)
· Leaking/contaminated fuel injectors or fuel pressure regulator
· Low fuel pressure or running out of fuel (fuel pump concern, fuel supply line restrictions, low fuel level, etc.)
· Vapor recovery system (stuck VMV, etc.)
Induction System:
· MAF contamination
· Air leaks between MAF and throttle plate
· PCV system / Other vacuum leaks
· Improperly seated engine oil dipstick
EGR System:
· Leaking gasket
· Stuck EGR valve / Leaking diaphragm or EVR
Base Engine:
· Oil overfill
· Incorrect cylinder compression
· Exhaust leaks before or near the HO2S
· Secondary air stuck on
ToasterOven
Reged: 09/28/05
#1299136 (Re: Tony2005) 08/12/06 02:02 PM
no, i changed the bank one sensor one last time(firewall side)
Base Engine:
how about stuck off? when i changed my plugs last, i think i may have knocked that smart box thingy under the plastic cover. cause after i changed my plugs, it had no top end whatsoever. then after about a week, it felt like they would come on in first and then shut off right before it shifted into second. Its an ATX.
now, it seems to run fine during colder times like nights and mornings, but not always when its warm out midday.
thanks again for all the help, its been priceless to me so far.
99 V6SE Sport ATX
ToasterOven
Reged: 09/28/05
#1301131 (Re: ToasterOven) 08/15/06 09:42 PM
any body got some more help for me? i really still dont know what to check for that last code.
99 V6SE Sport ATX
#1301163 (Re: ToasterOven) 08/15/06 10:34 PM
P1151, maybe change the Bank 2 upper O2 sensor. Not running right when hot could be the start of IMRC failure.
This thread for P1151
This thread for IMRC failure or start thereof
ToasterOven
Reged: 09/28/05
#1301571 (Re: Tony2005) 08/16/06 03:16 PM
alright, cool. im gonna try fixing my IMRC with a new transistor and changing the 02 sensor. if that dont fix it, ill be back. thanks for all the help thus far.
now i still need to find out why my lights are flashing with the power fluxuations. i looked at me battery cables, and the positive side is all corroded and torn, exposing a not very good looking wire. i cleaned it, and within a couple days, it was back to its corroded self. would maybe changing this wire help?
99 V6SE Sport ATX
#1301580 (Re: ToasterOven) 08/16/06 03:25 PM
...now i still need to find out why my lights are flashing with the power fluxuations. i looked at me battery cables, and the positive side is all corroded and torn, exposing a not very good looking wire. i cleaned it, and within a couple days, it was back to its corroded self. would maybe changing this wire help?
Yes. You could try covering it with liquid rubber (?) and tape it up to see if that helps. Also check for a loose ground (especially wires which go under the battery and Power Distribution Box).
ToasterOven
Reged: 09/28/05
#1301584 (Re: Tony2005) 08/16/06 03:30 PM
alright, cool. will do. looks like i got alot to do this weekend
thanks again for all the help.
99 V6SE Sport ATX
Generated in 0.092 seconds in which 0.084 seconds were spent on a total of 14 queries. Zlib compression enabled.
