Goonz SVT
Reged: 05/18/04
Loc: Pakistan, MA
Re: MISSFIRING **Update** new
#1214875 (Re: MapOfTaziFoSho) 04/13/06 02:55 AM
fair enough, I'll try it tommorow, thanks pete..if my wires are legit then it obviously has to be my plugs then correct?
MapOfTaziFoSho
Reged: 09/01/02
Loc: The E.L.
#1214900 (Re: Goonz SVT) 04/13/06 03:17 AM
Most likely...I replaced my plugs once with the brand new coil and they foiled again. I took the coil back under warranty and am now running a brand new one in my 3L, with new plugs, and the old magnacores.
Born again on 04/09/06
FOR SALE:
Moonroof glass and motor MB sunshade
PM ME!
FavoriteMystaque
Reged: 10/17/04
#1215524 (Re: MapOfTaziFoSho) 04/14/06 12:14 AM
Try checking plug gaps, I ran mine at .050, a little less than specified for the standard Duratec, so they spark earlier. Seems good over 6 months.
Big Jim
Reged: 09/03/00
#1215715 (Re: FavoriteMystaque) 04/14/06 04:38 AM
Closing the gap also diminishes spark intensity. My experience has been that you should set at the high end of spec for most cars. You don't close the gap unless you have boost.
Jim Johnson
98 SVT
03 Escape Limited
Mod-deth
Reged: 04/15/02
Loc: Not too close to you...
#1215825 (Re: Big Jim) 04/14/06 01:04 PM
(Carson on)
I did not know that
(Carson off)
FavoriteMystaque
Reged: 10/17/04
#1216309 (Re: Mod-deth) 04/15/06 12:05 AM
Yes, I knew that about spark intensity. I do believe Less gap=less voltage=less likely to carbon track, so far so good for me. I imagine if voltage was too low=narrow gap, it could misfire too.
Goonz SVT
Reged: 05/18/04
Loc: Pakistan, MA
#1216368 (Re: MapOfTaziFoSho) 04/15/06 01:43 AM
voltage seems fine..so i guess its off to getting new plugs..i have autolites in at the moment so which ones should I go with now?
FavoriteMystaque
Reged: 10/17/04
#1216410 (Re: Goonz SVT) 04/15/06 02:44 AM
Try this topic: Plug tracking/misfiring There are links to pictures of carbon tracking in that topic, and you should use silicone grease in the plug boots. Make sure the sparkplug socket wrench is clean as well, to prevent tracking. Try a new set of stock wires (motorcraft/autolite). I hope you fix it, I hated that misfiring when I had it!
Johnnytar
Newbie
Reged: 04/10/06
#1216534 (Re: FavoriteMystaque) 04/15/06 01:04 PM
We've tried new coil, new wires, and plugs, also playing a bit with the gap and to no avail. I'm now turning to checking the Idle Air Control valve for sticking.
BeetleJuice
Newbie
Reged: 04/15/06
Loc: BR
#1216648 (Re: Johnnytar) 04/15/06 05:26 PM
hi,
i am new here and i'm having the same problem.. after changing fuel pump and EGR sensor misfire problem reduced but it's still there annoying at low revs ... do you guys think i should go for plugs/wires/coils replacement??
regarding brands magnecor seems to be very good from your posts but i dont think i can buy them around here so my options are stock, ngk or bosch ..
thx
Mondeo CLX 2.0 Mk2
0 registered and 15 anonymous users are browsing this forum.
Generated in 0.078 seconds in which 0.073 seconds were spent on a total of 14 queries. Zlib compression enabled.
