NVMYSVT
Reged: 01/06/03
Loc: Wisconsin
Re: MISSFIRING **Update** new
#1225033 (Re: 2X95SEs) 04/26/06 10:47 AM
thought I would whip in here and give an update as to my condition..
I changed the fuel filter last weekend and after that it got about a million times worse.. Infact after I did that I could barely keep the car running.. Decided that I was going to do a little investigating in areas I could not see as I swapped the damn wires and coil pack 3 times w/o success!
I started searching everywhere for a vacuum leak and all of a sudden I saw the culprit..
I must have hit a pretty nice bump and the Crankshaft position sensor wiring came out of being tucked up inside an engine cavity and fell against the serpentine belt and was rubbing.. it didn't cut it in half but it rubbed the wires completely raw in spots and I assume that it just kept getting worse with each test drive and test rev I did with the engine.
so we cut the wires and spliced it back together and then ziptied the wiring all nice, neat and tight so it cant happen again
The car runs like a goddamn top now..
Not sure if we just didn't push the wiring back on the same pegs or whatever when we rebuilt it and dropped it back into the car or this could happen to someone else with hitting bumps pretty hard -- but if anyone ever has some of the same symptoms I had its worth looking at your wiring to the crankshaft position sensor..
I hope the rest of you have figured out your running problems.
Crispy
99 Cougar - Arancio Atlas/Grey Graphite Pearl Custom Widebody
98 CSVT - Silver Frost #4014/6535 - Born 10/21/97
98 CSVT - Silver Frost #4085/6535 - Born 11/10/97
See My Rides
getsum111
Reged: 04/05/05
Loc: Freedom, Pa
#1225040 (Re: NVMYSVT) 04/26/06 11:27 AM
Good for you. Nice investigating work!
Scott
Mabe I WILL be Phil.
1999 Contour SVT, Tropic Green
BAT kit, K&N RU-3530+MAF, Magnecore 8.5mm, some audio goodies, Hightowers, Knauberized, tatoo by Parkedcar.
Goonz SVT
Reged: 05/18/04
Loc: Pakistan, MA
#1225600 (Re: NVMYSVT) 04/26/06 11:19 PM
hmm i should check mine out! where is it located?
#1225631 (Re: Goonz SVT) 04/27/06 12:16 AM
... where is it located?
From Ford CD.
Crankshaft Position Sensor
Removal
1. Disconnect battery ground cable.
2. Raise vehicle on a hoist (or jack up and put on jack stands).
3. On 2.5L engine-equipped vehicles, remove splash shield from RH front fender apron.
4. Disconnect the fuel charging wiring or engine control sensor wiring (depending upon application) from the crankshaft position sensor (CKP sensor).
5. Remove crankshaft position sensor retaining bolt and remove crankshaft position sensor.
Installation
1. Make sure crankshaft position sensor mounting surface is clean. If equipped, make sure that the crankshaft position sensor O-ring is in proper location on crankshaft position sensor.
2. CAUTION: Do not overtighten crankshaft position sensor retaining bolt or damage to the crankshaft position sensor may occur.
Position crankshaft position sensor and install retaining bolt. On 2.0L engine-equipped vehicles, tighten retaining bolt to 6-9 N-m (53-80 lb-in). On 2.5L engine-equipped vehicles, tighten retaining bolt to 8-12 N-m (71-106 lb-in).
3. Properly route fuel charging wiring or engine control sensor wiring (depending upon application) and connect electrical connector to crankshaft position sensor.
4. On 2.5L engine-equipped vehicles, install splash shield. Tighten retaining screws securely.
5. Lower vehicle.
6. Connect battery ground cable.
Picture compliments of Chongo.
Originally posted by chongo:
See if the wires harness is lose. Tough to test it as the PID's on the service cd need the car running.
Autozone sells them for $13.99
CRANKSHAFT POSITION SENSOR
1998 FORD CONTOUR WELLS SU292 3 MO $13.99
Goonz SVT
Reged: 05/18/04
Loc: Pakistan, MA
#1227375 (Re: getsum111) 04/28/06 06:48 PM
okay my car is still missfiring..after a new coilpack, new wires, new plugs and a new TPS..only thing I haven checked is the crankshaft position sensor yet..I will do that tonight but other then that i have no idea what to do now?
my SZ hopes are slowly fading..
NVMYSVT
Reged: 01/06/03
Loc: Wisconsin
#1227545 (Re: Goonz SVT) 04/28/06 10:16 PM
Good Luck Goonz
Crispy
See My Rides
0 registered and 18 anonymous users are browsing this forum.
Generated in 0.079 seconds in which 0.074 seconds were spent on a total of 14 queries. Zlib compression enabled.
