Pages: 1 | 2 | >> (show all)
Goonz SVT
Reged: 05/18/04
Loc: Pakistan, MA
!@#$%^& IDLE RANT!!
#1187349 - 03/09/06 05:07 AM
Im soo sick of this issue! Ive done all i can just so this stupid idle dipping up and down problem would go away but noooo!!! I did the following hoping it would go away..
*UIM/LIM Cleanup
*New IAC
*Cleaned MAF
*TH Fix (i dont think that had anything to do with it)
*New TPS
now there are no vacuum leaks at all, or that i know off..However one concern i do have, upon installing the new TPS, I didnt callibrate it or anything, is that why maybe my idle is still bad? if so what can I do to fix it? thanks
intravino
Reged: 09/10/04
Loc: Montreal, QC, Canada
Re: !@#$%^& IDLE RANT!! new
#1187352 (Re: Goonz SVT) 03/09/06 05:09 AM
Hello,
I think I have the same problem on my 96 Zetec.
The RPM goes from 800 to 400 every 2 seconds.
I need a fix.
www.carplugs.com
OBD2 Scantools
OBD2 Cables
OBD2 Connectors
OBD2 Free Software
Rogerm60
Reged: 10/11/02
#1187428 (Re: Goonz SVT) 03/09/06 06:32 AM
The TPS requires no calibration .
Fluxuating idle is almost always a vacuum leak.
The O2's would have to be terrible to cause it.
If you installed new gaskets on the LIM, UIM, TB, IAC, and EGR valve - pull the top two lines and plug them. If that's not it, give the PCV valve and hose to the intake a good inspection (or plug the intake port). The formed elbow often gets soft and leaks or collapses.
If you still have a problem, spray the UIM end plugs with carb cleaner for a test.
Goonz SVT
Reged: 05/18/04
Loc: Pakistan, MA
#1187433 (Re: Rogerm60) 03/09/06 06:39 AM
all O2's are brand new as of 2 days ago..still the same problem..I did break the vacuum hose from the brake booster to the UIM, but I did get a new one and fix it. I guess the only other thing left is the PCV as you said..where is the PCV?
BrApple
Reged: 12/23/01
Loc: Enfield, CT
#1187513 (Re: Goonz SVT) 03/09/06 01:00 PM
down under the tb, remember the tube that comes off the UIM under the TB? that attaches to the pcv valve
- 95 Mystique LS - Zetec/5spd
hoger29
Reged: 02/01/06
Loc: Iowa
#1187618 (Re: BrApple) 03/09/06 03:51 PM
I have the same issue with my 96 contour. I havew changed the MAF, Cleaned the IAC, Fuel Filter, Air filter, Checked countless items.
I was wondering what the gasket looked like when you installed the new IAC. Was it like 2 O rings or was it a big gasket covering the entire mating surface?
I also was wondering if you checked the spark plugs I have heard this suggestion many times.
hoger29
Reged: 02/01/06
Loc: Iowa
#1187981 (Re: hoger29) 03/09/06 10:03 PM
I just fixed my idle problem( I hope) with cleaning out the IAC and installing a new figure 8 gasket. I also found that the fat O ring on the bottom of the plenum chamber was not seated right and probably caused an air leak between it and the throttle body. You may want to check the fat O ring. Did you install a new gasket with IAC as well?
Goonz SVT
Reged: 05/18/04
Loc: Pakistan, MA
#1187992 (Re: hoger29) 03/09/06 10:22 PM
my IAC is brand new..what o-ring are you talking about?
hoger29
Reged: 02/01/06
Loc: Iowa
#1187997 (Re: Goonz SVT) 03/09/06 10:34 PM
The O ring was at the bottom of the plenum chamber and on top of the throttle body, it had nothing to do with the IAC. However you should have replaced the figure 8 gasket that is located between the IAC and engine. Did you replace that? that was all I replaced on my car and just cleaned the IAC because couldn't find new one for under 110 dollars.
todras
I have no life
Reged: 05/29/00
Loc: Grand Rapids, MI
#1188617 (Re: hoger29) 03/10/06 08:20 PM
Hope you used a Ford IAC also.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
svtavino
Reged: 05/16/01
Loc: CT
#1188658 (Re: Goonz SVT) 03/10/06 09:14 PM
Sure you got the right tps? I know autozone didn't have the right one in their computer a couple years ago when I needed to replace mine. Not sure if our cars have two fluid temp sensors but I did some work on my truck which has two and one wasn't hooked up and I had a bad idle sitiation. Once it was fixed it ran perfect.
Green 2000 SVT #1166
mods-K&N and Custom heat shield, optimized y pipe, Magnaflow center resonator, DMDhttp://www.geocities.com/savinoss/Cars.html
-Wifes car 99 Mystique V6 5 spd
svtProdigy
Reged: 12/13/04
Loc: Carol Steam, IL
#1188716 (Re: svtavino) 03/10/06 10:31 PM
Could it be his fuel pumpfreakin out from bad voltage comingfrom a bad alternator?
PLEASE HELP ME GET MY CAR TOGETHER! ITS IN DAYTON OHIO! I need the motor together and in the car so i can DRIVE it! Pleeeeeese!
diamond pistons for 3.0/forsale
#702 of 2150
Goonz SVT
Reged: 05/18/04
Loc: Pakistan, MA
#1188885 (Re: todras) 03/11/06 04:01 AM
Ford IAC and Ford TPS..
my alternator could be bad? I think its fine, how should I troubleshoot that?
o another thing, I was making a left turn in second gear while letting go of the clutch, the car seemed to have sputtered for a bit and I was like wtf untill it cought the gear like 3-5 seconds late.. I dont know what the hell it was, it was very awkward..plus today I re-did my throttle hang fix with a smaller hole which worked out perfectly and kiiiiinda fixed my idle thing, it still sometimes drops low and then jumps up..this is getting quite annoying
juspifool
Reged: 03/31/02
Loc: Erie, PA
#1306334 (Re: Goonz SVT) 08/25/06 01:17 PM
Goonz,
I am having these same problems. Did you ever get it fixed?
1998 T-Red SVT Contour
#2588 of 6535
2005 F-150
Pre98
Reged: 12/31/03
Loc: Cheektowaga, NY
#1306641 (Re: juspifool) 08/25/06 09:50 PM
It was sputtering while turning? Sounds like a vacuum leak. When you're turning, the engine ups the revvs a bit to accomodate the power steering. I bet somewhere in your CAI is the problem (mine too)
0 registered and 46 anonymous users are browsing this forum.
Generated in 0.863 seconds in which 0.855 seconds were spent on a total of 14 queries. Zlib compression enabled.
