Modifications >> Transaxle
Pages: 1 | 2 | 3 | (show all)
Pole120
Reged: 03/16/04
Loc: New Berlin, WI
Re: Tranny Drain/Fill How-to W/PICS new
#969314 (Re: Ray) 06/14/05 01:52 PM
Originally posted by Ray:
The drain plug is on the bottom.. the fill is on the side.
LOOSEN fill (make sure it WILL loosen)
remove drain, as stated.. drain it.
replace drain plug.
remove fill plug and fill until fluid begins to spill out of the fill plug. (technically the procedure calls for 0.5mm below the fill bore)
The inconsistencies in this how-to are due to gross negligence on my part, and a (seemingly blatant) inability to cope without sleep.
Apologies to all.
Ray
thanks for clearing it up, no apology necessary, its a great how-to
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
OFace12
Reged: 05/22/05
Loc: Braselton, GA
#986095 (Re: Pole120) 06/29/05 11:39 PM
I have a quick question... why did you point out the clutch bleeder in the pictures? is there something that I supposed to do with that?
1999 SVT Contour
Magnaflow Dual Exhaust
KKM High Flow Intake
SVTatGT
Reged: 11/30/04
Loc: Georgia Tech
#986566 (Re: OFace12) 06/30/05 12:59 PM
Thats just an FYI for realative location of the plug. You don't need to do anything with the clutch bleeder, but if you allready know where it was and you couldn't find the tranny plug, that picture would help you find it
Cameron
98 Black CSVT #2958
Ray
Reged: 07/10/01
Loc: San Antonio/Austin, TX
#987013 (Re: SVTatGT) 06/30/05 07:14 PM
exactly.. that picture was a relative picture, and its been floating around here for a LONG time. I happened to use it, as it helps in describing the location.
As with ALL my how-tos.. I state: Follow the DIRECTIONS to a "t" and you will have no problems, regardless of whether or not a picture "makes sense".. I commonly tear apart my car to illustrate a howto without an actual need to do the procedire, so I may visually skip a step that I tell people to do.
"do as I say, not as I do" type of thing.. LOL
Ray
'99 CSVT - Silver #222/276
OFace12
Reged: 05/22/05
Loc: Braselton, GA
#987086 (Re: Ray) 06/30/05 08:09 PM
Ok, thanks for the clarification.
1999 SVT Contour
Auto-X Fil
Reged: 08/11/03
Loc: Pennsylvania
#987110 (Re: Ray) 06/30/05 08:27 PM
Unless you say to leave the drain plug off, right? You should probably fix the FAQ and delete all these posts to clarify the issue. I did it for you, since you're overworked here as it is:
Drain Procedure:
  • Raise and support the vehicle. DO NOT WORK UNDERNEATH THE VEHICLE WITHOUT SOME MEANS OF SUPPORT (other than the jack itself). Jacks are not meant to SUPPORT the weight, only to lift it temporarily.. Failure to heed this warning could result in SEVERE INJURY OR DEATH.
  • Locate the MTX FILL plug. We want to find the fill plug first, even though it is full (for now). Using either the 8mm allen wrench, or the T50 torx bit, we need to loosen the plug just to make sure it WILL loosen. It would really suck to drain your tranny, then find out you can't put more in!
    The fill plug is located on the forward edge of the tranny as noted in this picture.
    You can make out the waterpump pulley on the upper left of the picture, for reference. It is underneath the front bumper, just to the rear of the lower splash shield.
  • re-tighten the fill plug (just so no dirt gets in there, though you shouldn't have taken it OUT.. just break it loose.
  • Locate the drain plug. It is located on the passenger side of the lowest part of the tranny. You can get a better overall understanding of it (and the entire process) by looking at this picture (source unknown)
  • Place your drain pan underneath the drain plug, and loosen the drain plug, draining whatever you can from the transaxle. Be sure you replace the drain plug!
  • completely remove the FILL plug, now.
  • Using the pump, begin adding your fresh fluids to the MTX. This is a "fill-till-spill" process, so add fluid until you have reached the fill plug's opening, and begin to lose fluid.
  • replace fill plug
  • lower the vehicle
  • dispose of old fluid according to locally enforced laws.
-Philip Maynard
2006 autocross results
Ray
Reged: 07/10/01
#987138 (Re: Auto-X Fil) 06/30/05 08:56 PM
That's what the post below it stating the correction was for.. how many people who DON'T know how to change the fluid (hence reading the how-to) aren't going to read the other posts below (perhaps containing other tips, etc)??
I appreciate the effort, but the reason we avoid that sort of thing would be for posterity. Simply deleting responses that don't "work", line up well, or sound right, isn't an option.
Should I simply delete your post, as well, because it doesn't "look good" beneath the how-to we wrote in the first place?
If a mistake is made, then it is far better to leave it, and also include the FIX, rather than only provide the correct way. This way, if someone makes the SAME mistake, they can find the FIX for it, and not just a bunch of posts on how to do it properly the first time.
(granted, this particular issue is a text issue and not a PART issue, but the principle is the same)
and...
I'm in no way overworked, but thanks for assuming I cannot handle any workload I volunteered for.
Ray
Edited by Ray (06/30/05 08:58 PM)
stadtsoldat
Reged: 11/22/04
Loc: Fort Collins, CO
#1075381 (Re: Ray) 10/14/05 01:20 AM
If you have only the front up on jackstands, should you lower it before adding the liquid? Otherwise you change the point of the fill plug in reference to the center of the tranny, and you increase the amount of liquid in there. But does it matter? Is it better to have more fluid?
1999 SVT, Tropic Green
No mods yet
www.cardomain.com/id/stadtsoldat
Big Jim
Reged: 09/03/00
#1075413 (Re: stadtsoldat) 10/14/05 02:06 AM
I fill with the front up on ramps, but I leave the plug out and lower the car and allow it to spill if it will and then reinstall the plug.
Jim Johnson
98 SVT
03 Escape Limited
Tuned3900SFI
Reged: 11/22/03
Loc: Michigan
#1075641 (Re: Big Jim) 10/14/05 12:59 PM
If you lower the car, how do you squeeze back under there to put the plug back in? I've done this how to before (and it is FANTASTIC Ray!!), but I don't see how it is possible to do this. Putting the front on ramps, drain it, jack the rear up and set the rear on jackstands so that the car is reletivly level, then fill it. That is how I have always done it.
..Just a note for Ray, every How TO that you have done, I have printed up, laminated, and stuck in a 3 ring binder. I appreciate all of them, makes life so much easier and keeps me organized. When I want to do a UIM/LIM rebuild, change the fuel filter, change the trans fluid, etc.. I just whip out my book, turn to that section, and bam.
2006 Pontiac G6 3900SFI GTP Coupe
CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint
Former Owner- 2000 "Stryped" CSVT
CEG Dragon Run- Oct 13-15
0 registered and 5 anonymous users are browsing this forum.
HTML is enabled
Generated in 0.081 seconds in which 0.075 seconds were spent on a total of 14 queries. Zlib compression enabled.
