Modifications >> Transaxle
Pages: 1 | 2 | >> (show all)
wk217
Reged: 07/02/00
Loc: Brisbane, CA
TSS - is it supposed to spin freely?
#1218416 - 04/18/06 05:05 AM
Ok guys. Having problems with the CD4E on my '99 Contour. I do not currently have 2nd or 4th (OD) gears. Transaxle shifts from 1st directly to 3rd. The OD light will blink after a while, but not always. I've already done a drain and fill (3 days ago) - just 4 qts, and am about to do another one right now. I also ordered a TSS from Bill Jenkins that arrived today, and may change it out if time permits, otherwise, i will do one more drain and fill, and change the TSS along with my motor oil tomorrow. (doing the cheap fixes first)
My question is, the new TSS does not seem to "spin". Is it supposed to? I want to make sure the new TSS is not defective BEFORE I put it in. Please advise ASAP. Thanks in advance.
wk217
2003 Focus SVT, Black w/ European Package
26000 miles (Totalled)
1999 Contour SE Sport, Silver, V6 ATX
140,000 miles and counting
fastcougar
Reged: 05/30/00
Loc: Kearneysville, WV
Re: TSS - is it supposed to spin freely? new
#1218427 (Re: wk217) 04/18/06 05:37 AM
TSS (turbine speed sensor) is a magnetic pickup sensor ... you might be thinking of the VSS (vehicle speed sensor). So, yes, you are right, it IS NOT supposed to "spin". Here is how you change it:
http://www.newcougar.org/forums/showthread.php?t=1451
For Sale: 1997 Explorer XLT V8 AWD
Edited by fastcougar (04/18/06 05:38 AM)
wk217
Reged: 07/02/00
Loc: Brisbane, CA
#1218428 (Re: fastcougar) 04/18/06 06:05 AM
Thanks for the quick reply... and yeah, I just right now figured it out when the old one I took out didn't spin either. Thanks again.
Now I just hope it solves my problem.
wk217
wk217
Reged: 07/02/00
Loc: Brisbane, CA
#1218432 (Re: wk217) 04/18/06 06:22 AM
Well, it was not the TSS, as I still have the same problem. Guess I should buy and replace the VSS next? And if that doesn't work, guess the next thing I'm buying is a Mazdaspeed6 GT Unless there are other suggestions.
wk217
fastcougar
Reged: 05/30/00
#1218436 (Re: wk217) 04/18/06 06:36 AM
Based on your problem description, I would suspect the valve body.
projectSHO89
Reged: 09/19/02
Loc: St. Louis, MO
#1218511 (Re: fastcougar) 04/18/06 01:04 PM
Or a shift solenoid. Certainly not a VSS. A fault with the INT/OD band and/or servo will also cause a no 2nd/4th condition.
Here's an idea: Since the O/D light is flashing, how about following the manual and READ YOUR CODES.
The codes will tell you what the computer has detected is not correct. With those codes, you can quit parts-swapping and do some real doagnosis...
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
#1218542 (Re: wk217) 04/18/06 01:44 PM
Originally posted by wk217:
... Guess I should buy and replace the VSS next? ...
No, if your speedometer is working fine, don't replace the Vehicle Speed Sensor (VSS). Scan the PCM and post the codes.
If you want to do a last ditch grasp straws item before the tranny rebuild or new car purchase, change the Manual Lever Position Sensor ($50).
MLPS change.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1040336&page=&view=&sb=5&o=&fpart=1&vc=1
Edited by Tony2005 (04/18/06 01:46 PM)
wk217
Reged: 07/02/00
Loc: Brisbane, CA
#1218655 (Re: fastcougar) 04/18/06 03:13 PM
Actually, I've actually been trying to get the codes read...
I purchased the OBD-2 scanner from Alex Peper a while back, (Group Buy, I believe) but have been unable to read the codes with that unit.
1. Is that unit capable of reading these codes?
2. If so, how?
Thanks.
Pick
Reged: 08/16/02
Loc: Houston, TX
#1218722 (Re: wk217) 04/18/06 04:05 PM
Go to your local Autozone or wherever and they will scan your codes for you, usually for free.
Then get back to us.
"Not a newbie" Been here since it all started!!
98 silver SVT Contour
several mods and counting
www.pickettperformance.com
"Remember, you're part of the human race, try not to embarrass the rest of us"
projectSHO89
Reged: 09/19/02
Loc: St. Louis, MO
#1220258 (Re: wk217) 04/20/06 01:49 AM
2. If so, how?
Thanks.
Yes, it can do it.
email Alex for support. One undocumented security feature is that software will not allow a connection to the vehicle's computer (will get a failure to connect message) until you enter the registration code.
Alex can help you if you have misplaced the code. He'll look it up by some identifier. In my case, it was my email address.
Steve
94 SHO ATX - 190K
unisys12Moderator
Reged: 09/08/02
Loc: Corinth, MS
#1222118 (Re: wk217) 04/22/06 01:03 AM
2. If so, how?
Thanks.
Again, yes... the unit should be able to read these codes. Only difference is that to see the codes, you will have to be driving with the laptop hooked to the car. When the O/D light starts to blink, it should log to the codes in the software.
From the CD4E FAQ's -
From the `98 Ford Service CD -
"The MIL is illuminated for all emissions related electrical component malfunctions. For malfunctions attributable to a mechanical component (such as a clutch, gear, band, valve, etc.), some transmissions are capable of not commanding the mechanically failed component and providing the remaining maximum functionality (functionality is reassessed on each power up)- in such case a non-MIL Diagnostic Trouble Code (DTC) will be stored and, if so equipped, a Transmission Control Indicator Light (TCIL) will flash."
What this basically means, is that the CEL will illuminate, and stay that way, during an emmissions related electrical component faliure or malfunction. That is until the PCM memory is either cleared manually or the fault is not detected after two consecutive drive cycles.
If there is a mechanical failure, in the tranny, it will cause the TCIL (O/D light) to flash, which means that the PCM has stored a code indicating which fault it was. But!! This code will be cleared once the engine is turned off.
So. If your O/D light flashed, there was a code there to be read. If you turned your engine off before you could actually read that code, that code would disappear. If when you started your car again and the CEL was not on or the O/D light did not flash, there is nothing there to read. You will have to wait until the fault happens again.
Hope that helps
Phillip Jackson
`98 Mystique LS
262K+ and counting...
ATX rebuilt @ 151K
"This storm has broken me, my only friend!" RIP Dime
wk217
Reged: 07/02/00
Loc: Brisbane, CA
#1222846 (Re: unisys12) 04/23/06 06:55 AM
I will try to pull the codes on Monday... and post them, if any.
HTML is enabled
Generated in 0.022 seconds in which 0.016 seconds were spent on a total of 14 queries. Zlib compression enabled.
