Modifications >> Transaxle
Pole120
Reged: 03/16/04
Loc: New Berlin, WI
Re: Linkage *DELETED* new
#1022201 (Re: PÕWDÉ®CØÃTMÀŃ) 08/11/05 02:10 AM
Post deleted by unisys12
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
PÕWDÉ®CØÃTMÀŃ
Reged: 02/15/05
Re: Linkage new
#1022219 (Re: Pole120) 08/11/05 02:33 AM
Thats odd I jsut looked all over my CD and I can't even find the MTX-75 listed . I have
AX4N
AX4S
F4EIII
F4E TYPE F
CD4E
CD4E is the one listed for the Contour / Cougar / Mystique
Check me out for awsome powder coating deals
www.powdercoatingworld.com
People shouldn't slam each other when posting, If you cant say something good to say then just hit the back arrow.
CSVT#49
Reged: 05/28/04
Loc: Coon Rapids, MN
Re: Linkage new
#1022282 (Re: PÕWDÉ®CØÃTMÀŃ) 08/11/05 03:31 AM
Any chance of getting that removal instruction post deleted? That way we can avoid confusing people. Grant it there may be some useful info there... but yea wrong trans.
-Mike
-Mike
98 Contour SVT
Toreador Red #49 of 6535 Built on 3/25/97
WR Headers, Borla Cat-Back, Torsen T2 LSD, K&N Short Ram, S-AFC and Focus Shift Tower
85 Camaro
1969 358ci, 97 TA interior, 91 Z28 GrdEfx and Aero Wing 255rwhp
PÕWDÉ®CØÃTMÀŃ
Reged: 02/15/05
Re: Linkage new
#1022286 (Re: CSVT#49) 08/11/05 03:34 AM
-Mike
I just tried to edit it and remove it , I was actually trying to help out but I guess that didn't work as planned , A mod will remove it I'm sure.
CSVT#49
Reged: 05/28/04
REMOVAL INSTRUCTIONS new
#1023108 (Re: PÕWDÉ®CØÃTMÀŃ) 08/12/05 12:06 AM
I know you were trying to help. Thanks for trying, so since there seems to be a demand... Heres the correct way:
Special Tools Needed (According to Ford)
Support Bar, Engine 21 - 140
Adapter for 21-140, 21 - 140 - 01
Adapter for 21-140, 21 - 140 - 02
Adapter for 21-140, 21 - 140 - 03
Hi - Lift Transmission Jack 014 - 000942
Powertrain Fixture 134 - 000250 (optional)
Impact Slide Hammer, T50T-100-A
Metric Hub Remover Adapters, T83P-1104-BH
CV Joint Puller, T86P-3514-A
Removal
1.Remove the battery. For additional information, refer to «Section 414-01».
2.On both sides undo the suspension strut nut five turns.
3 CAUTION:
Lock the steering wheel.
Use wire or tie strap to secure the radiator.
4.Remove the engine air cleaner (A/C). For additional information, refer to «Section 303-12B».
5.Remove the water pump cover.
(1) Disconnect the engine coolant hose.
(2) Remove the bolts.
(3) Remove the water pump cover.
6. Disconnect the accelerator and speed control cables.
(1) Disconnect the speed control cable, if equipped.
(2) Disconnect the throttle cable.
7. Disconnect the accelerator and speed control cables (SVT Vehicles only).
(1) Unclip the cables from the bracket.
(2) Disconnect the accelerator and speed control cables.
8. Disconnect the ground cable and position it aside.
9. Note:
Drain the power steering reservoir.
Disconnect the power steering reservoir hose.
(1) Disconnect the power steering reservoir from the bracket by lifting up.
(2) Reposition the hose clamp.
(3) Disconnect the power steering reservoir hose.
10. Disconnect the vehicle speed sensor (VSS) electrical connector and reversing lamp switch electrical connector.
11. Disconnect the fuel lines. For additional information, refer to «Section 310-00».
12. Disconnect the starter motor electrical connectors.
13. Remove the air cleaner bracket and the starter motor bracket.
(1) Remove the air cleaner bracket.
(2) Remove the starter motor bracket.
14.CAUTION:
Do not spill brake fluid onto painted surfaces.
Remove the clutch slave cylinder hydraulic pipe.
15. Remove the bolts and the starter motor.
Refer to corresponding illustration.
16. Install the Support Bar, Engine.
17. Remove the LH transaxle support insulator.
(1) Remove the nuts.
(3) Remove the LH transaxle support insulator.
18. Remove the LH transaxle support insulator studs.
19. Remove the four upper bellhousing bolts.
20. Remove the front wheels.
21. Detach the lower wheel arch covers (right-hand side shown).
22.CAUTION:
Do not damage boot and ABS - Sensor Ring.
Disconnect the lower suspension arm ball joints and the stabilizer link rods (right - hand side shown).
(l) Disconnect the ABS wiring harness bracket from the suspension strut.
CAUTION:
To aviod to damage joints and boots, do not bent the inner halfshaft joint by more than 18 degrees, the outer one by not more than 45 degrees.
Note:
Oil escapes. Close of the transmission openings with auxiliary plugs.
23. Remove the right - hand halfshaft and intermediate shaft.
(l) Secure the right - hand halfshaft out of the way with mechanic's wire.
CAUTION:
24. Note:
Disconnect the left - hand halfshaft.
25. Remove the radiator splash shield.
(1) Remove the bolts.
(2) Remove the push pins.
(3) Remove the radiator splash shield.
26. Remove the secondary three - way catalytic converter.
(1) Remove the two nuts.
(2) Remove the secondary three - way catalytic converter.
27. Note:
LH side shown, RH similar.
Remove the radiator support brackets.
(2) Remove the radiator support brackets.
28. Remove the bolt and position the bumper bracket aside.
Vehicles with air conditioning
29. Remove the suction accumulator bracket bolts.
30. Remove the heated oxygen sensor electrical connector from the subframe.
31. Remove the intermediate shaft pinch bolt.
32. Remove the front roll restrictor.
(1) Remove the through bolt.
(2) Remove the nuts.
(3) Remove the front roll restrictor.
33. Remove the rear roll restrictor.
(3) Remove the rear roll restrictor.
34. Remove the rear roll restrictor bracket.
35. Loosen the subframe bolts and lower the subframe.
36. Disconnect the shifter cables and bracket.
(1) Disconnect the shifter cables from the shifter lever.
(3) Position the shifter bracket aside.
37. Remove the power steering line bracket bolt and disconnect the power steering line from the steering gear.
38. Remove the subframe bolts and subframe.
39. Position Hi - Lift Transmission Jack and secure holding strap to transaxle.
40. Remove the lower rear bellhousing bolts.
41. Remove the lower front bellhousing bolt and nut.
42. Lower the engine and transaxle assembly.
43. Separate the transaxle from the engine and remove the transaxle.
And There you have it folks, straight from the Ford service manual CD (Sorry I didn't get the images in with the post)
-Mike
98 Contour SVT
85 Camaro
CSVT#49
Reged: 05/28/04
INSTALLATION INSTRUCTIONS new
#1023130 (Re: CSVT#49) 08/12/05 12:25 AM
Special Tools (again according to Ford)
Powertrain Fixture, 134-000250 (optional)
Powertrain Alignment Tool, T94P-6000-AH
Hi-Lift Transmission Jack, 014-000942
Sub Frame Alignment Pin Set, T94P-2100-AH
Installation
1. Position the transaxle to the engine using Hi - Lift Transmission Jack.
2. Install the eight bellhousing bolts.
3. Disconnect the holding strap and remove Hi - Lift Transmission Jack.
4. Note:
Do not tighten the bolts
Install subframe and subframe bolts.
5. Note:
Use new seals for the power steering lines.
Install the power steering line bracket bolt and connect the power steering lines on the steering gear.
6. Attach the shifter cables and bracket.
(1) Position the shifter cable bracket.
(2) Install the nuts.
(3) Attach the shifter cables.
7. Note:
The power steering pressure hose must be correctly routed while positioning the subframe.
Note:
The intermediate shaft must be correctly aligned to the steering gear while positioning the subframe.
Tighten the subframe.
(1) Install the Subframe Alignment Pins.
(2) Align the subframe with the locating holes in the body.
(3) Install the subframe bolts working diagonally.
8. Install the rear roll restrictor bracket.
9. Install the rear roll restrictor.
(1) Install the bolts.
(2) Install the through bolt hand tight.
10. Install Powertrain Alignment Tool.
(1) Position Powertrain Alignment Tool.
(2) Install the bolts.
(3) Install the through bolt hand tight.
11. Install the intermediate shaft pinch bolt.
12. Attach the heated oxygen sensor electrical connector to the subframe.
13. Install the suction accumulator bolts to the subframe.
14. Install the bumper bracket.
15. Note:
LH side shown, RH side similar.
Install the radiator support brackets.
(1) Position the radiator support brackets.
16. Install the secondary three - way catalytic converter.
(1) Position the secondary three - way catalytic converter.
17. Install the Y line. For additional information, refer to «Section 309-00».
18. Install the radiator splash shield.
(1) Position the radiator splash shield.
(3) Install the push pins.
19. Install a new snap-ring.
CAUTION:
20. Note:
Do not damage the oil seal. Check that the snap - ring engages correctly.
Install the left - hand halfshaft.
CAUTION:
21. Note:
Install the right - hand halfshaft.
22. CAUTION:
Connect the lower suspension arm ball joints and the stabilzer link rods.
(l) Attach the ABS wiring harness bracket to the suspension strut.
23. Install the lower wheel house covers (right - hand side shown).
24. Install the front wheels.
25. Note:
The fill level is 0-5 mm below the lower edge of the filler hole.
Check the transmission fluid level and fill up Transmission Fluid if necessary.
26. Lower the vehicle.
27. Install the four upper bellhousing bolts.
28. Install the LH transaxle support insulator stud.
29. Note:
Do not tigthen the bolts and nuts.
Install the LH transaxle support insulator.
(1) Install the nuts.
(3) Install the LH transaxle support insulator.
30. Install the starter motor and bolts.
31. Connect the starter motor electrical connectors.
32. CAUTION:
Install the clutch slave cylinder hydraulic line.
33. Connect the fuel lines. For additional information, refer to «Section 310-00».
34. Bleed the clutch slave cylinder hydraulic system. For additional information, refer to «Section 308-00».
35. Connect the vehicle speed sensor (VSS) electrical connector and backup lamp switch electrical connector.
36. Loosen RH engine support insulator nuts.
(1) Disconnect the wire retainer.
(2) Loosen the nuts.
37. Note:
Use new self - locking nuts.
Tighten the LH transaxle support insulator.
38. Tighten the RH engine support insulator nuts.
(1) Tighten the nuts.
(2) Connect the wire retainer.
39. Install the air cleaner bracket and the starter motor bracket.
(1) Install the starter motor bracket.
(2) Install the air cleaner bracket.
40. Connect the ground cable.
41. Raise and support the vehicle. For additional information, refer to «Section 100-02».
42. Note:
Verify that rear roll restrictor is centered in the bracket and in perfect front to rear alignment before tightening the through bolt. As necessary, loosen the roll restrictor to subframe mounting bolts and reposition the roll restrictor.
Tighten the rear roll restrictor through bolt.
43. Remove Powertrain Alignment Tool.
(3) Remove the Powertrain Alignment Tool.
44. Note:
Verify that the front roll restrictor is centered in the transaxle bracket and in perfect front to rear alignment before tightening the through bolt.
Install the front roll restrictor.
(1) Position the front roll restrictor.
(3) Install the through bolt.
45. Lower the vehicle.
46. Remove the Support Bar, Engine.
47. Connect the accelerator cable and speed control cables.
(1) Connect the accelerator and speed control cables.
(2) Connect the throttle cable.
48. Connect the accelerator and speed control cables (SVT Vehicles only).
(2) Clip the cable into the bracket.
49. Connect the power steering reservoir hose.
(1) Position the power steering reservoir hose.
(2) Position the hose clamp.
(3) Install the power steering reservoir.
50. Install the water pump cover.
(l) Attach the engine coolant hose and install the bolts.
51. Remove the radiator supports.
52. Tighten the front wheels (right hand side shown).
(1) Wheel nut
(2) Driveshaft stub nut
53. Note:
Use an Allen wrench to stop the piston rod from turning.
Tighten the suspension strut locknuts (right - hand side shown).
54. Tighten the suspension strut locknuts with a torque wrench (right - hand side shown).
55. Install the battery tray. For additional information, refer to «Section 414-01».
56. Fill up and bleed the power steering system. For additional information, refer to «Section 211-00».
Again theres everything from the Ford service manual CD (minus pictures)
Well that removal and installation was a heck of a lot of editing. Didn't copy and paste well from the CD. I guess that gives a complete run down for this HOW-TO though. I'm sure there will be a lot of people that can benefit from this. Good luck with your endeavors guys!
-Mike
98 Contour SVT
85 Camaro
akrump47
Reged: 12/23/02
Loc: Novi or Dearborn MI
Re: INSTALLATION INSTRUCTIONS new
#1025614 (Re: CSVT#49) 08/15/05 02:53 PM
AWESOME write-up, but it says nothing about replacinig the syncromesh?? They always fail with high mileage ...
E0 3781
CSVT#49
Reged: 05/28/04
#1026356 (Re: akrump47) 08/16/05 04:02 AM
Sorry man didn't need to replace mine. Maybe when my transmission goes out in the future I'll do a write-up on that too.
-Mike
98 Contour SVT
85 Camaro
Hdbngr8
Reged: 04/30/04
Loc: At a baseball game....somewhere
Re: MTX-75 Upgrade How-To new
#1038397 (Re: unisys12) 08/30/05 10:15 PM
This is a most excellent how-to. Have you considered having Terry Haines look at it and comment?
'98 SVT Red/midnight blue - a few mods
E0 wheels for sale - PM me
warmonger
Reged: 08/16/01
Loc: Ozark, AL
#1038401 (Re: Hdbngr8) 08/30/05 10:25 PM
Don't worry, I'm sure he's seen it by now. Hell, indirectly a bunch of info came from him anyway through all the pooling of knowledge on here.
See My Mods
0 registered and 4 anonymous users are browsing this forum.
HTML is enabled
Generated in 0.022 seconds in which 0.015 seconds were spent on a total of 14 queries. Zlib compression enabled.
