Modifications >> Suspension
Pages: 1 | 2 | (show all)
ohsigmachi
Reged: 07/23/01
Loc: Mililani, Hawaii
Adjustable front sway bar endlinks
#1312223 - 09/04/06 09:18 PM
Linky
Has anybody used these? They seem expensive. Are there any alternatives out there?
Ohsigmachi '96 GL MTX Zetec
--I don't won't to hurt you, but it's still on my list of things to do.--
View projectSlippery Slope
starjammir
Reged: 08/14/04
Loc: Lapeer, Mi
Re: Adjustable front sway bar endlinks new
#1312259 (Re: ohsigmachi) 09/04/06 11:02 PM
There is the stock replacement or go to NAPA. If you do racing you will need em, otherwise stock will do fine.
1998.5 SVT contour #5979 3L
1995 Mercury Mystique 2.5L auto, all ghetto fo sho
Kremithefrog
I have no life
Reged: 05/14/02
Loc: Albany, Georgia
#1312284 (Re: ohsigmachi) 09/04/06 11:45 PM
That's too much. If you know where to look, I'm sure you can put them together yourself for much cheaper.
And the ad says heim joints are bad, it's been my understanding that heim joints are good.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
bensenvill
Reged: 02/29/04
Loc: Chicago
#1312337 (Re: Kremithefrog) 09/05/06 01:30 AM
well heim joints take maintence [or at least the occasional inspection], which you can interpret as "bad".
either way its nice to see a new product [I've never seen any discussion on adjustable front endlinks]
yes... I am a cougar owner trolling on your board.
RogerB
Reged: 10/21/00
Loc: Wichita, KS
#1312567 (Re: ohsigmachi) 09/05/06 12:39 PM
So, you adjust their length, but I don't see how that can help you unless you're oval tracking, in which case you might adjust them unevenly to preload the bar to resist lean to the right. Otherwise, if you adjust both links to the same length, the effect will be zero, regardless whether they are short or long.
Function before fashion.
'96 Contour SE
Pole120
Reged: 03/16/04
Loc: New Berlin, WI
#1312639 (Re: RogerB) 09/05/06 03:43 PM
way overpriced.
I can build something similar for half the price.
~Josh
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
RogerB
Reged: 10/21/00
Loc: Wichita, KS
#1312681 (Re: Pole120) 09/05/06 04:55 PM
Originally posted by Pole120:
way overpriced.
~Josh
Again, why? I just don't see the advantage.
'96 Contour SE
Stazi
Reged: 11/18/00
#1312711 (Re: RogerB) 09/05/06 05:53 PM
+1
Waste of money.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
tsSVT
Reged: 01/31/04
Loc: oklahoma city
#1312722 (Re: Stazi) 09/05/06 06:15 PM
Just so everyone knows,If you go to ford to buy new endlinks,all they carry now are the light alloy links from the Mondeo.I work at a Ford dealership and, went to buy a new link, and realized what they had done.Plus,they only cost me like $13 a piece instead of $25 from SPmotorsports.
2000 Silver SVT
Auto-X FilModerator
Reged: 08/11/03
Loc: Pennsylvania
#1312759 (Re: tsSVT) 09/05/06 07:56 PM
Adjustable end links are nice because your frame, bushing mounts, and endlinks mounts aren't always perfectly symmetrical. You also might need to adjust your endlink mounting points when corner-balancing. You want zero preload on your swaybars, so to do it right you should disconnect the endlinks, corner-balance, adjust them to zero preload and then reconnect the endlinks. It's a fine-tuning kind of thing that makes the difference between 1st and 2nd: it's a very small gain, but real.
Unless you're running coilovers and corner-balancing the car correctly already, it's worth absolutely nothing.
And yes, there are much cheaper ways to make them. $50 worth of parts from McMaster-Carr would do just as well, and $100 worth of parts would be better quality. Or you could buy a RH and LH die, and cut and thread a stock endlink, and just put a hex RH/LH shaft in the middle.
starjammir, that was a worthless BS post-whore response. You didn't have a clue what these were for, so why did you post? I'd prefer an honest "I have no idea why you'd need them" to your "if you're racing you'll need them" crapshoot.
-Philip Maynard
2006 autocross results
Auto-X FilModerator
Reged: 08/11/03
Loc: Pennsylvania
#1312760 (Re: Kremithefrog) 09/05/06 08:05 PM
A greased, booted ball-joint will last longer and be smoother and quieter than a Heim (or "spherical rod-end") joint, especially in a dirty environment. However, they're more expensive and good Heim joints can be lined with Teflon or other materials for long life and smooth action. They're also easier to fasten/unfasten since they have a bolt hole, and you don't waste a joint if you crossthread or strip something. They're also harder to work with and find, which is why you often don't see them on custom stuff. I'd imagine in general Heim joints are slightly lighter as well.
But of course, I'm sure you could find a workable ball-joint rod-end from McMaster for our application, if long, quiet, maintenance-free life is important for you. It's probably not if it's a race car, where these parts would be useful, so I don't see any reason to fab some with the better joints.
-Philip Maynard
Moderator:  Andy W., Auto-X Fil
Generated in 0.022 seconds in which 0.014 seconds were spent on a total of 14 queries. Zlib compression enabled.
