Modifications >> Suspension
Pages: 1 | 2 | >> (show all)
timeless420
Reged: 11/09/00
Loc: Thornhill, Ontario
Re: Koni and Ground Controls new
#1206586 (Re: todras) 04/03/06 08:11 AM
Originally posted by todras:
I don't know how they can't get bent when you tighten them. They are about as strong as a wet noodle. Tony's plates are a must IMO.
I see what you are talking about but they are mainly an asthetic issue rather than a functionality issue. Until somone gives me another vaild concern that these stock caps affect the actual functionality of the camber kit/strut mounts I will still not accept this as a true upgrade except unless you consider it weight reduction since your wallet will be lighter after
Then: 99 Silver Frost SVT #1919
237hp/219tq All Motor
Now: 06 White STI
Parts 4 sale
Auto-X FilModerator
Reged: 08/10/03
Loc: Pennsylvania
#1206594 (Re: timeless420) 04/03/06 08:27 AM
I agree. I've never used the cheapo plates - I got a pre-bent set and an upgraded set when I bought the kit used. But, I can tell you that I would not want to torque ANY plates to spec. Factory spec torque is for the centered plates. They are designed to let the strut shaft move in the tower, sliding the plate with it. When you offset things, you change the geometry of the motion, and the bending forces on the shaft skyrocket. I am glad the plates bend - they're giving way instead of the strut! After the hat is settled into the tower, it will take a lot of force to dislodge and rotate it, so having the cap just finger-pressure snug against the top of the tower seems like good prevention of it actually coming out far enough to do damage, but nothing else.
I find that the nut holding the top plate on sits against the nut on the strut hat, so I can't snug the plate down anyway, FWIW.
-Philip Maynard
2006 autocross results
0 registered and 38 anonymous users are browsing this forum.
Moderator:  Andy W., Auto-X Fil
Generated in 0.09 seconds in which 0.075 seconds were spent on a total of 14 queries. Zlib compression enabled.
