General >> Group Buy
Pages: 1 | 2 | 3 | (show all)
Pole120
Reged: 03/16/04
Loc: New Berlin, WI
P.R.T. Optimized Throttle Bodies new
#1275719 - 07/11/06 12:42 AM
Another qualitly PRT product:
Included in the service:
1) Throttle body is completly disasembled and cleaned with CEG's imfamous Berrymans B12 carb cleaner.
Shaft\Plate
2) Untapped portion of TB shaft is removed, cut is cleaned with file.
3) Tapped portion of shaft is thinned to a uniform profile, edges are radiused, and polised.
4) TB plate is countersunk with 90 degree countersink and polished to a mirror finish.
5) Plate and shaft are assemebled with 90 degree screws and exposed screw segments are filed down flush with shaft.
Housing
6) Housing inlet is knife edged and blended to remove all obstruction.
7) Rough internal casting portions are smoothed and lightly polished.
8) Housing exterior is bead-blasted to a like-new bare aluminum finish.
9) Housing and all parts are cleaned again to remove any remaining particulate.
10) TB is re-assembled and shipped.
11) TB linkage is modified to ensure TB is 100% open at WOT.
This process results in the equivalent of increasing TB diameter to 63mm.
Pricing
SVT: $60 + $150 core charge
SE V6: $60 + $75 core charge
SE I4: $70 + $75 core charge
If you are sending your Tb to be optimized, core charges do not apply. Multiple Tb discounts also available.
All prices include return shipping.
Turnaround time is a bit long at about a week, as I got out of town to have the housings cleaned, if you don't want the bead blasting service for quicker turnaround, let me know, and I can get one out the door within 2 days. I will not be doing these pre-order, when you place your order I start on your TB.
TPS is to be removed prior to shipping to eliminate chances of damage (I am not responsible for damage if it's left on), no cleaning of the TB is necessary, I will take care of it all
Current core list:
SVT- 2
SE V6- 1
SE I4- 0
The pics:
Note: ** Housing inlet is not knifedged in this picture **
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Pole120
Reged: 03/16/04
Loc: New Berlin, WI
Re: P.R.T. Optimized Throttle Bodies
#1276155 (Re: Pole120) 07/11/06 04:14 PM
Current core list:
SVT- 1
SE V6- 1
SE I4- 0
Totaled 02/12/06
CSVT1214
Reged: 11/02/03
Loc: Plainville, CT
Re: P.R.T. Optimized Throttle Bodies new
#1276239 (Re: Pole120) 07/11/06 05:31 PM
Josh, just a heads up. I didn't forget about this. I'll be shipping out both of mine hopefully this week for you to get started on.
Also, PM me with a price for the powdercoating we discussed when you get a chance. Thanks.
Tony
mond12345
Reged: 06/12/05
#1276379 (Re: CSVT1214) 07/11/06 08:16 PM
Pm'd
Icefury
Reged: 02/13/01
Loc: Minneaoplis, MN
#1276408 (Re: mond12345) 07/11/06 09:28 PM
Pm'd
2000 CSVT Frost Silver 3.0 Hybrid
Pole120
Reged: 03/16/04
Loc: New Berlin, WI
#1276423 (Re: Pole120) 07/11/06 10:06 PM
Current core list:
SVT- 0
SE V6- 1
SE I4- 0
I'm alerted when i revieve a PM, no need to post it here
Totaled 02/12/06
svtProdigy
Reged: 12/13/04
Loc: Carol Steam, IL
#1278778 (Re: Pole120) 07/14/06 06:24 PM
[image]
you should smooth out that big hump inside the throttle body or at least make the transition smoother...for a lil extra mula..
PLEASE HELP ME GET MY CAR TOGETHER! ITS IN DAYTON OHIO! I need the motor together and in the car so i can DRIVE it! Pleeeeeese!
diamond pistons for 3.0/forsale
#702 of 2150
Pole120
Reged: 03/16/04
Loc: New Berlin, WI
#1278785 (Re: svtProdigy) 07/14/06 06:35 PM
Can we not make this a re-peat of the last thread????
I do smooth it out, bad pic. I can't get that deep with my tools to do any better of a job without possibly damaging the mating surface of the TB plate....not to mention the difference would be beyond negligable to be worth the time.....
Totaled 02/12/06
Dr. Cross
Reged: 08/20/02
Loc: Burlington, VT
#1282411 (Re: Pole120) 07/20/06 01:10 PM
I received/installed my P.R.T Optimized TB and must say the work is top notch. It's hard to tell w/ the butt dyno if there's any hp gain, but throttle response does seem improved. Don't know if it's wishfull thinking or not but engine sounds a little throatier too. Looking forward to future products from P.R.T!
1999 Contour SVT #1966/2760, Silver Frost/Midnight Blue
Koni Kit, Mille Miglia MM-S rims, B&M shifter, Stazi mesh, SFCs, optimized Y-pipe & TB, SS break lines, K&N drop-in, Infinity Kappa speakers, MTX amp/sub
Pole120
Reged: 03/16/04
Loc: New Berlin, WI
#1288190 (Re: Dr. Cross) 07/28/06 02:44 PM
Thanks for the kind words
Current core list:
SVT- 1
SE V6- 1
SE I4- 0
Totaled 02/12/06
0 registered and 50 anonymous users are browsing this forum.
Moderator:  1314
Generated in 0.029 seconds in which 0.022 seconds were spent on a total of 15 queries. Zlib compression enabled.
