General >> General
Pages: 1 | 2 | (show all)
contour_phoenix_when
Reged: 02/21/01
Loc: brooklyn,ny,usa
structure identification so that it may be replace
#356058 - 07/22/03 03:58 PM
Looking from the front of the Contour there is one flap that hangs down that is a cover for the towing hooks used to pull the car on and off car trailers it is my under standing. Those flaps are attached to some structure that is beginning to hang down evermore. What is this structure called I would like to replace it. This structure seems to cover the front under carriage of the Contour?
Stazi
Reged: 11/18/00
Re: structure identification so that it may be replace new
#356136 (Re: contour_phoenix_when) 07/22/03 04:50 PM
It's usually called the "front splash guard"
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Reged: 02/21/01
#356151 (Re: Stazi) 07/22/03 05:06 PM
Well how much does it cost to replace. because mine seems to be sagging.
Andy W.
b0x @dm1n
Reged: 07/19/00
Loc: Columbia, MD
#356204 (Re: contour_phoenix_when) 07/22/03 05:44 PM
The older ones are two piece the newer ones are a single peice. I would suggest getting on that is a single piece because lots of dirt tends to college between the two seperate pieces.
-Andy
Andy W.
The problem with America is stupidity.
I'm not saying there should be a capital punishment
for stupidity, but why don't we just take the safety
labels off of everything and let the problem solve itself?
Reged: 02/21/01
#356211 (Re: Andy W.) 07/22/03 05:49 PM
I guess this is a dealer only product as well?
crusinmercury
Reged: 03/13/03
Loc: FL, Melbourne
Re: structure identification so that it may be rep new
#356233 (Re: contour_phoenix_when) 07/22/03 05:59 PM
you could always pop one off a car in a junkyard..that's a part that the junkyard don't usually take off
ATX -
Originally posted by bnoon:
Get enough HP/TQ and some traction and you can race a ricer one handed while sipping a slirpy. Nothing wrong with that.
<font class="post">
16.251@85.42 mph
Reged: 02/21/01
#356238 (Re: crusinmercury) 07/22/03 06:04 PM
Anyone know how much this part might cost?
dbird
Reged: 04/16/02
#357693 (Re: contour_phoenix_when) 07/23/03 11:19 PM
we had one that was hanging down on a 96 contour.. when changing the oil i removed it and never put it on correctly... just use a torx screw driver and remove it and then make sure the plastic inserts that go into the cross member under the car are placed in correctly and put the screws back in... aobut 4 under the cross memebe and two on each side right in front of the tires..... sure beats buying another one for about $150.00 from the dealer......
garrick
Reged: 01/30/01
Loc: Denver, CO
#358297 (Re: contour_phoenix_when) 07/24/03 03:22 PM
Front splash guard is what I would call it as well. I take mine off each time I change my oil (makes filter access much easier IMO).
If it's a one-piece unit like I have, there are about 9 Torx screws holding it on. Are all the screws in place on your splash guard? If not, I'd suggest replacing those screws first (take one of the screws with you to most any auto parts store, and look in the small trim bits/emergency repair parts section). Might save you a whole lot of trouble.
Since I don't know what year your 'Tour is, I'm just guessing, of course...
Garrick
2006 Mazda6 Grand Sport wagon, silver, MTX
I'll never forget you: Silver E0, #3895 of 6535, built 10/2/97
Reged: 02/21/01
#358326 (Re: garrick) 07/24/03 03:44 PM
95 v6 ATX
TourDeForce
Reged: 03/04/03
AHEM... new
#358408 (Re: contour_phoenix_when) 07/24/03 04:37 PM
Those are called the front air seal for some odd reason. If you ask for a splash guard they'll know what you're talkin' about, so no problem.
My cost for a new one on my car was under $80.
My daughter likes to park right up against the wheel stops.
Her ZX-2 has the air seal missing too.
0 registered and 15 anonymous users are browsing this forum.
Moderator:  GTO Pete, Trapps
Generated in 0.034 seconds in which 0.028 seconds were spent on a total of 14 queries. Zlib compression enabled.
