General >> General
Pages: 1 | 2 | 3 | 4 | 5 | 6 | (show all)
Pole120
Reged: 03/16/04
Loc: New Berlin, WI
What would you like to see come out of PRT? new
#1269373 - 06/29/06 05:31 PM
Loking for CEG's input on products and services to be released from PRT's shop for the CDW-27 crowd. I've got several products in mind and in the works that are listed below, but i'ld also love for you guys to supply me with any products you'ld like to see released.
Suspension:
-Boxed front 2-bolt LCA's with shperical bearings in place of the bushings
-Tubular forward and rear arms for the rear suspension
-Tubular and triangulated RSTB
-Upgraded rear subframes
-Spherical endlinks for front and rear swaybars
-Front LCA boxing plates for 2 and 4 bolt arms
-Harness bar, perhaps with a camera mount
Performance:
-Beyond-optimized y-pipe, steps are taken to go beyond the usual optimiation for maximum flow, will be flow tested.
-Optimized TB's
-Fiberglass heatshields
-Fiberglass pin-on hood and trunk
-Mandrel cat-back fabrication
Asthetics:
-Powder and ceramic coating at insanly good prices
-Fiberglass paintable tank(p/s,brake,overflow) and battery covers, i may also look into haveing them CF wraped
-Acid dipped badges, antenna bases, grill rings for painting
-Badgeless SVT stock mesh grill - still working on this, may or may not happen on a more than one scale.
-Molded\repaired Splitters - no job too big, you'll see what i mean soon enough
-Molded jack-point covers into skirts
-Molded gauge pod in place of coin tray
-Shaved front keyhole door handles
-Mirko skidplates
Services:
-Intake re-bilding
-Suspension swaps
-Header installs
....i've done most everything maintanance wise at least once.
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
striker2
Reged: 03/15/04
Loc: Glendale Heights, Il (for now)
Re: What would you like to see come out of PRT? new
#1269385 (Re: Pole120) 06/29/06 05:45 PM
tubular frt lower control arms with adjustable ball joints, and camber/caster adjustments for both 2 and 4 bolt designs (2 bolt will be easier obviosly, could use poly bushings or spherical links)
adjustable tie-rod ends to help eliminate bump steer for those that have extremly lowered their car.
frt strut tower braces that bolt to the towers and the firewall for added rigidity.
thats all i can think of for now.
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
Matt R
Reged: 06/06/04
Loc: Saratoga Springs, NY
#1269427 (Re: striker2) 06/29/06 06:36 PM
Excellent idea.
-Matt R
'99 Tropic Green LX, Zetec, ATX
GTO PeteModerator
Reged: 04/07/01
Loc: Rockville, Maryland
#1269431 (Re: Pole120) 06/29/06 06:40 PM
Some kind of high-strength, clear plastic to help protect all the breaking foglights.
Capitol CEG Classifieds
Make an offer!
2005 GTO IBM - 337hp/336tq
Jeb Hoge
Reged: 07/23/01
Loc: Midlothian, VA
#1269442 (Re: GTO Pete) 06/29/06 06:50 PM
Continued improvement on camber kits.
"Think of it, if you like, as a librarian with a G-string under the tweed." Clarkson on the Mondeo.
GTO PeteModerator
Reged: 04/07/01
#1269449 (Re: Matt R) 06/29/06 06:58 PM
Excellent idea.
Front strut tower bar that works with the camber kit.
Make an offer!
mystiquevltwin
Reged: 01/28/05
Loc: pittsburgh PA
#1269454 (Re: GTO Pete) 06/29/06 07:02 PM
maybe some kind of true CAI for us zetec guys
this is a strech...but an aftermarket grille for the mysiques? (top or bottom)
kevin m
98 T-red mystique gs
zetec ATX
| my ride |
CSVT1214
Reged: 11/02/03
Loc: Plainville, CT
#1269457 (Re: GTO Pete) 06/29/06 07:05 PM
+1
x 1000
Tony
ElKy
Reged: 10/10/01
Loc: Prince Spaghettiville
#1269459 (Re: CSVT1214) 06/29/06 07:06 PM
how about a $250 bolt on V8, all-wheel drive conversion kit?
NY State Trooper: So what makes your car so special to have SVT all over it?
Me: Er...It was made by Fords SPECIAL Vehicle Team?
GTO PeteModerator
Reged: 04/07/01
#1269463 (Re: ElKy) 06/29/06 07:08 PM
$250 shipped right?
Make an offer!
0 registered and 31 anonymous users are browsing this forum.
Moderator:  GTO Pete, Trapps
Generated in 0.038 seconds in which 0.032 seconds were spent on a total of 14 queries. Zlib compression enabled.
