General >> General
murky024
Reged: 08/14/06
Loc: State College, PA
New Contour Owner
#1299859 - 08/14/06 12:58 AM
Alright well I just wanted to say hi to everyone and introduce myself... My name is Mark and I just bought a '95 Ford Contour SE... It is pretty nice but I do have a few problems that I figured you regulars could help me out with.
First I notice a little bit of binding in the steering wheel when the car is warming up and it hasn’t been driven more than a couple miles... After a few miles it clears up and acts natural... I assume this may be related to the control arm bushings needing to be replaced. (a friend that owns a Contour said factory ones are known for it)
Second: The transmission shifts really hard into 2nd no matter how hard I am on the gas... I would assume its a pressure control solenoid and that a good flush or fluid change would clear up the issue. (Opinions?)
Thank you all for your help.
Mark
_________________________________________________
2000 Grand Prix GTP (best 1/4 mile 13.87 @ 100)
1995 Contour SE (Faster than the GTP because it doesn't have a chipped piston)
Re: New Contour Owner new
#1299865 (Re: murky024) 08/14/06 01:07 AM
Welcome Mark . First things first, what engine, how many miles and what tranny (auto or manual).
The hard steering could be due to dirty Power steering fluid (a good flush would help).
As for the hard shift to 2nd, if it is an auto, change the ATFluid and Turbine Shaft Speed Sensor.
ATFluid drain and refill in Transaxle FAQ
Turbine Shaft Speed sensor issue.
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=tranny&Number=257675&page=&view=&sb=5&o=&fpart=1&vc=1
and this
http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=1030582&page=&view=&sb=5&o=&fpart=all&vc=1
murky024
Reged: 08/14/06
#1299890 (Re: Tony2005) 08/14/06 01:53 AM
Oh, sorry about not mentioning the mileage... It has 79k on it... I think that is good for a '95... It is an auto... I wish it was a manual, that would make this car a lot more fun.
I will do a fluid change on the tranny and change the TSS while I am down there. Thanks for the help.
Also, the steering isnt hard it just has a two bind points. It gets bound when turning the wheel to the left or right from center. But it only does this when the car hasnt been on the road. After I get a mile or two own the road the points where the wheel would bind dont catch it... Also I do notice a sound when it happens so I will check it out when I am under the car draining the transmission and changing the TSS.
Thanks again for the help everyone...
#1299916 (Re: murky024) 08/14/06 02:39 AM
Check for wheel bearing or ball joint/tie rod issues.
Jack up the car. Place on jack stands.
Grasp wheel at 12 and 6 o'clock and push in and out. If there is excessive movement, most probably suspect wheel bearing. Confirm with someone stepping on the brakes. If the wheel bearings are the culprit, there should not be any movement now.
Grasp wheel at 9 and 3 o'clock and push in and out - If there is excessive movement, suspect tie-rod/ball joint. To confirm, push/pull on tie-rod/ball joint.
Mystique97
Reged: 07/16/04
Loc: Ashland, Ohio
#1299919 (Re: Tony2005) 08/14/06 02:44 AM
Welcome, and 79K is damn good for a 95 I'm impressed. My car has almost 83K on it and its a 97.
Jason G.
1997 Mercury Mystique GS ZETEC ATX
Born: 11/96
murky024
Reged: 08/14/06
#1300053 (Re: Tony2005) 08/14/06 11:41 AM
Is there any place I should get parts? I know for all the electronics on my Grand Prix I will go through a dealer to get AC Delco just because that is what the car prefers. But could I just go to Advance Auto or Pepboys to get the parts I am going to need for the TSS?
#1300225 (Re: murky024) 08/14/06 04:54 PM
Originally posted by murky024:
... But could I just go to Advance Auto or Pepboys to get the parts I am going to need for the TSS?
I don't think they have TSS in stock. Go with a local dealer or www.teamfordparts.com
FavoriteMystaque
Reged: 10/17/04
#1300570 (Re: Tony2005) 08/15/06 01:33 AM
Fords like Ford OEM parts Especially Contours and Mystiques.
LUCA
Reged: 12/28/01
Loc: Bethlehem, PA
#1300574 (Re: FavoriteMystaque) 08/15/06 01:36 AM
Mark, welcome to the CEG.
Phil
98 Silver Frost #2059
murky024
Reged: 08/14/06
#1300804 (Re: LUCA) 08/15/06 12:23 PM
Thank you all for the warm welcome... A friend of mine who recommended I buy a Contour told me about this site and you all have been very helpful. I am sure this place will be a great resource in helping me get my car into tip-top shape.
LUCA
Reged: 12/28/01
Loc: Bethlehem, PA
#1300831 (Re: murky024) 08/15/06 01:05 PM
State College?
You should check out the North East section. We have quite a few members in your area, they get together every now and again and I'm sure they would be glad to have you join them.
Phil
murky024
Reged: 08/14/06
#1300880 (Re: LUCA) 08/15/06 02:09 PM
Actually it is one of your members that turned me onto Contours and the site... Auto-X Fil is the guy that I hold responsible for me buying this Contour
LUCA
Reged: 12/28/01
Loc: Bethlehem, PA
#1300919 (Re: murky024) 08/15/06 03:09 PM
I figured that it was one of the CEG members.
Phil
TourDeForce
Reged: 03/04/03
#1301040 (Re: murky024) 08/15/06 07:06 PM
Oh, NO!!! Not HIM !!!
Just kidding! He's a good guy. He's been very helpful in the Auto cross SCCA section expecially. I've saved some notes from his posts & used his sage advise to improve my driving skills. His approach to Auto-X has been quite thoughtful & measured in many respects.
Since I've never said it before, thank him for me.
Auto-X Fil
Reged: 08/11/03
Loc: Pennsylvania
#1301056 (Re: murky024) 08/15/06 07:34 PM
Hey Mark, what's up? Here's Bill's contact:
Bill Jenkins
Internet Dept.
Team Ford
5445 Drexel Rd.
Las Vegas, NV 89130
800-791-6436
www.TEAMFORDPARTS.com
bjenkins@teamfordlv.com
He's faster on the phone than via e-mail. Just let him know you're from contour.org and ask for the CEG price. It's usually 10-30% off the prices listed on typical internet parts catalogs, which are already around 30-40% off list.
I'll be in town for the weekend of Sept 8-10 for the autocross. If you want to work on the 'tour on Saturday let me know. PM me here or on the lpac.
-Philip Maynard
2006 autocross results
murky024
Reged: 08/14/06
#1301109 (Re: Auto-X Fil) 08/15/06 09:07 PM
I might be up for working on it Saturday... The only thing is that without Justin's garage and tools I am very limited on tool offerings and garage space. I can borrow some stuff from him (or at least beg to borrow) if you tell me what you need and dont have.
Also tomorrow I will be draining and refilling the tranny, and installing the TSS.
Let me know what you want to do...
Edit:
Also, the part you were talking about... Control arm bushing or whatever... Is it the insulator on the pictures at this link:
http://www.trademotion.com/partlocator/index.cfm?action=getLocator&siteid=214270&chapter=DP2FM0&appSectionid=19&groupid=60858&subgroupid=0&componentid=0&make=10&model=Contour&year=1995&graphicID=FMP060&callout=2&catalogid=1
Edited by murky024 (08/15/06 09:14 PM)
Auto-X Fil
Reged: 08/11/03
Loc: Pennsylvania
#1301307 (Re: murky024) 08/16/06 02:26 AM
Nope, that's a subframe bushing. That picture shows the two-bolt control arms anyway, which aren't like yours. You're looking for the control arm bushings. The control arm - that stamped piece with a ball-joint on one end - has bushings on the other end where it bolts to the subframe. You have to replace the whole arm at once if the bushings are gone.
-Philip Maynard
murky024
Reged: 08/14/06
#1301520 (Re: Auto-X Fil) 08/16/06 02:02 PM
Well I cannot seem to find this 'Control Arm Bushing' in the list of parts for the '95... Is this something that is only on the SE and I need to call to order?
Also, I completely forgot that on Saturday I am heading up to New York to take my sister sky diving for her High School graduation... So I wont even be in State College that weekend.
If any of you have a part number for the control arm bushings that I need that would be great.
Thanks
Auto-X Fil
Reged: 08/11/03
Loc: Pennsylvania
#1301527 (Re: murky024) 08/16/06 02:07 PM
You can't order the bushings. You have to order the whole control arm. Are you sure yours are shot?
-Philip Maynard
todras
I have no life
Reged: 05/29/00
Loc: Grand Rapids, MI
#1301538 (Re: murky024) 08/16/06 02:24 PM
Thanks
http://www.trademotion.com/partlocator/index.cfm?action=getLocator&siteid=214270&chapter=DP2FM0&appSectionid=19&groupid=61005&make=10&model=Contour&year=1996&catalogid=1
$116 for left
$135 for right
Nima (96BlackSE) sells them for $99 a piece.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
RialKnight
Reged: 02/05/06
Loc: Racine, WI
#1301550 (Re: murky024) 08/16/06 02:45 PM
welcome to the CEG.
1997 Ford Contour SE
Car's D.O.B. 2-15-1997 from Ford-KC Plant
Black Lighting
http://www.cardomain.com/ride/2389976
murky024
Reged: 08/14/06
#1301585 (Re: Auto-X Fil) 08/16/06 03:32 PM
I am not sure mine are shot yet... Tonight I am going to Justin's to work on the car so I will check the tie rods and the bearings but if they are all good I think that my suspension noise and my 'steering' issues are related to the control arms... I will jack the car up and sit under it while someone turns the wheel so I can see/hear what is binding and track it down but if I cant do it that way because there is no load on the suspension I will just end up replacing parts until it goes away...
Also, does anyone make aftermarket control arms; anything with poly bushings so they last longer or something? I put about 30k a year on average on my car and I just cant be replacing control arms every 70k….
Auto-X Fil
Reged: 08/11/03
Loc: Pennsylvania
#1301598 (Re: todras) 08/16/06 04:07 PM
Originally posted by todras:
$116 for left
$135 for right
Before CEG discount. I'd expect Bill to be about 20% less than posted prices - shipped.
And sorry, no poly versions. It's the years as well as the miles that wear them, so these should last you a long time.
-Philip Maynard
murky024
Reged: 08/14/06
#1302048 (Re: Auto-X Fil) 08/17/06 02:46 AM
Well I changed the TSS, tranny fluid (looked brand new), and oil... Also I checked the bearings and the tie rod ends and they all seem good... I think my problem is blown lower motor mounts as my engine rocks and moves a TON when it is put into gear...
How hard are lower motor/tranny mounts to change on these cars?
Auto-X Fil
Reged: 08/11/03
Loc: Pennsylvania
#1302235 (Re: murky024) 08/17/06 12:15 PM
Pretty easy. It's just a couple bolts that are easy to get to, although they are big - air tools make it a snap. Let's break out the window weld, shall we?
-Philip Maynard
murky024
Reged: 08/14/06
#1302407 (Re: Auto-X Fil) 08/17/06 04:03 PM
Does anyone have any links to changing the motor mounts? I assume I will want to change upper and lower mounts...
Thanks
0 registered and 28 anonymous users are browsing this forum.
Moderator:  GTO Pete, Trapps
Generated in 0.036 seconds in which 0.03 seconds were spent on a total of 14 queries. Zlib compression enabled.
