General >> General
Pages: 1
BradfordScales
Reged: 07/22/04
A long time since I have posted here
#1296514 - 08/09/06 02:32 AM
I need the help of your membership. I have a '97 GL Bi-Fuel Zetec that runs on natural gas most of the time. Within the last few months I've lost compression on the end cylinders, down to around 30 -> 65 psi. I don't think this is a ring problem as the oil level never goes down as I would expect from wall or ring wear or breakage. The engine has 67K and early in it's life the head was milled to true the surface.
I am suspecting a warped or burnt valve surface and my question is: Is the Bi-Fuel head the same component as the gasoline engine head assembly. From what I researched on RockAuto.com they are the same part # but seeing as this is a bit of a rare bird, I'm coming to the well of knowledge to help me confirm this.
Brad
Grow up! Quit asking stupid questions! And quit acting like you know it all!!!!
RaraAdministrator
"Absolut Rara."
Reged: 09/09/00
Loc: Westland, MI
Re: A long time since I have posted here new
#1296525 (Re: BradfordScales) 08/09/06 02:39 AM
I don't know for sure on the 2.0L Zetec, but typically the differences between a standard gas head, and a flex-fuel head is the engine valves and seats. The flex-fuel valves and seats tend to be made of a different material to improve wear when using the E85 fuel.
For all practical purposes, you are very likely to be just fine using a standard head in your situation.
Balance is the Key.
rarasvt@comcast.net
Kremithefrog
I have no life
Reged: 05/14/02
Loc: Albany, Georgia
#1296562 (Re: Rara) 08/09/06 03:37 AM
The car he is speaking of does not run e85, it runs cng ... natural gas. So it would be different than a vehicle set up to run e85.
I have never seen any part numbers as far as the cylinder heads and valves go for the bi-fuels, so I expect them to be identical to regular zetecs.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Pages: 1
0 registered and 3 anonymous users are browsing this forum.
Moderator:  GTO Pete, Trapps
Generated in 0.05 seconds in which 0.044 seconds were spent on a total of 14 queries. Zlib compression enabled.
