General >> General
Pages: 1 | 2 | >> (show all)
djdanyloz
Reged: 02/05/05
Best rear jack point?
#1280116 - 07/17/06 01:48 PM
So over the past few year I've been jacking the rear right on the y-weld of the exhaust near the back. This was suggested to me by stazi. Well now with my bosal I've spent a good ammount of time with cable ties positioning the system just right amd dont want to mess it up by lifting on it.
My jack wont get to a usual jack point because of the car's height. And when I do go on the exhaust the only place to put the handle of the jack is through the wheel well.
I searched the forum and found a spot and it seems there's a boxed spot on the subframe used as well.
Any advice on a new lift spot is appreciated as I'm tired of lifting the exhaust tips behind the bumper
BrApple
Reged: 12/23/01
Loc: Enfield, CT
Re: Best rear jack point? new
#1280117 (Re: djdanyloz) 07/17/06 01:52 PM
i use a few peices of wood and lift the car at about the middle of the back door from the side, from under the car you will see a bracket that holds the parking brake cable and right next to that a flat spot just at the front edge of teh rear seat, normally use to jacks and lift both sides at once.
- 95 Mystique LS - Zetec/5spd
IRingTwyce
Reged: 07/01/03
Loc: Graham, TX
#1280120 (Re: BrApple) 07/17/06 01:56 PM
Yeah, but if his car is too low to use the jack points on the sides, then it's DEFINITELY too low to use the side sill w/ wood between the car and the jack.
todras
I have no life
Reged: 05/29/00
Loc: Grand Rapids, MI
#1280124 (Re: IRingTwyce) 07/17/06 01:59 PM
Either of the tow hooks next to the exhaust pipes. Nothing stronger.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
BrApple
Reged: 12/23/01
Loc: Enfield, CT
#1280125 (Re: IRingTwyce) 07/17/06 01:59 PM
then use some 2x4s and drive the car up on that, my car is lowered on eibachs and now with SVT side skirts this still works to help get the jack under the car ...
IRingTwyce
Reged: 07/01/03
Loc: Graham, TX
#1280126 (Re: BrApple) 07/17/06 02:01 PM
Yeah, that's a good idea.
frenchblueC2
Smurfette
Reged: 05/14/01
Loc: Manchester, NH
#1280127 (Re: IRingTwyce) 07/17/06 02:02 PM
yeah, quite a few people here drive up onto boards.
It helps a lot.
Kim
1995 Contour GL
Needs less "needs more"
Big Daddy Kane
Reged: 07/22/03
Loc: Ramstein AB, Germany
#1280208 (Re: todras) 07/17/06 04:03 PM
Mine bent pretty easily with a floor jack and block of wood...
Goin' Round Traffic Circles @ 50Km/h!!!
\m/ -- 1998 E0 SVT #2119 of 6535
\m/ -- 2003 Sentra SE-R Spec V
djdanyloz
Reged: 02/05/05
#1280224 (Re: djdanyloz) 07/17/06 04:29 PM
Yea I'll try driving up on wood, I really wanted a less nerve-racking approach. Since everytime on the exhaust it would pop the tips behind the bumprer fairly forcefully and the jack's arm needed to be positioned perfectly so that when lowered the arm clears in the wheel wheel. It sucked raising the thing as the clearance was only like 4" so it took alot of time to pump the thing up to a decent height.
Thanks
todras
I have no life
Reged: 05/29/00
#1280316 (Re: Big Daddy Kane) 07/17/06 06:51 PM
Jack up every Contour I work on there. Never an issue. You sure you know what I'm talking about?
-'96 SE MTX 3L
Moderator:  GTO Pete, Trapps
Generated in 0.036 seconds in which 0.03 seconds were spent on a total of 14 queries. Zlib compression enabled.
