Modifications >> Brakes
Sarge43
Reged: 11/17/03
Loc: Tillamook, OR
Rear Drum to Disc Conversion
#459664 - 11/20/03 12:43 AM
I'm in the process of trading for a "00" Mystique GS with rear drums. How difficult would it be to swap out the drums for disc's? This is my first venture into the Contour/Mystique marque, I have a "98" Stang (which I will be selling )(done a bit to her) and an "01" Escape (box stock, so far.)
Thanks for any help
Sarge43
"00" Tique 2.0L I4 ATX
"98" Mustang 3.8L V6 AT
The reason there's so much ignorance is that those who have it are so eager to share it.
Edited by Andy W. (01/26/04 02:32 PM)
SVT power
Reged: 08/22/01
Loc: Metro Detroit
Re: Rear disc's new
#459804 (Re: Sarge43) 11/20/03 08:52 AM
It shouldn't be too bad considering the parts are a available since it was a factory option. Basically if you tried it on a car that only had rear drums from the factory I would be much harder. You may or may not have to change the hub though, but if you are willing to invest the time and money, it can be done.
'99 Black/Tan SVT
#291 of 2760
Tinted
Mirko Splitter
Pioneer 8400MP & 3-way 6x8's
Clear corners
Custom SVT banner
A-Pillar pod with Volt, Oil Temp & Press. gauges
B&M
Diamond Blue Fogs
White HVAC
the99svttour@yahoo.com
Big Jim
Reged: 09/03/00
Re: Rear disc's new
#460625 (Re: Sarge43) 11/20/03 11:18 PM
This should be helpful. The one thing I don't agree on is the removal of the rear brake pressure valves. Otherwise it is a great article.
http://www.contour.org/mods/mods.php?s=howto&displayid=1
Jim Johnson
98 SVT
03 Escape Limited
kinger
Reged: 08/15/01
Loc: Clear Lake, IA
Re: Rear disc's new
#460804 (Re: Big Jim) 11/21/03 08:40 AM
Your right I'll send Lance the new revised version, DON'T REMOVE THE RESTRICTOR!
I offer PnP Heads for all durtec's details at PnPheads.com or jesse@pnpheads.com for details.
Big Jim
Reged: 09/03/00
Re: Rear disc's new
#461941 (Re: kinger) 11/23/03 12:03 AM
I just realized that I should mention that there are different part numbers on the restrictors if the car has ABS, so use ABS restrictors on a car with ABS and non ABS restrictors if the car is not equipped with ABS. They look just about the same.
Jim Johnson
98 SVT
03 Escape Limited
PeterM
Reged: 04/01/03
Loc: Calgary
Re: Rear disc's new
#537509 (Re: Big Jim) 02/20/04 07:35 PM
I want to do this. Can't find any reasonably priced used knuckle/caliper/rotor assemblies.
Any one have any?
PeterM
Reged: 04/01/03
Loc: Calgary
Re: Rear disc's new
#540190 (Re: PeterM) 02/23/04 09:34 PM
Found lots on car-part.com. Any one know if the Cougar knuckles will fit?
Thinkmoto
Reged: 12/07/02
Loc: Wisconsin
Re: Rear disc's new
#540465 (Re: PeterM) 02/24/04 04:19 AM
Yes cougar knuckles will fit. As long as they are for a V6 4 wheel disc brake equipped car. I have cougar knuckles on my SVT
06 GMC Sierra 2500HD Dmax/ally
06 Pontiac G6 GT
05 CRF250R
FOR SALE 06 KX65 with riding gear $2700 obo
SleeperZ
Reged: 04/16/02
Loc: near Tacoma, WA
Re: Rear disc's new
#570117 (Re: Thinkmoto) 03/26/04 12:26 PM
The part number for the rear ebrake cables that I hae is F6RZ-2A635-AA, which is a kit with 2 cables and the uprated pulloff springs.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
TourDeForce
Reged: 03/04/03
Re: Rear disc's new
#574126 (Re: Big Jim) 03/30/04 08:11 PM
This thread is for replacing drums with discs. Did any drum brake equipped cars come with ABS?
Loco4G63
CEG road warrior
Reged: 08/01/01
Loc: IL
Re: Rear disc's new
#576834 (Re: TourDeForce) 04/02/04 12:59 AM
Mine did.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
mattmatt
Reged: 11/03/03
Loc: abilene,tx
Re: Rear disc's new
#590837 (Re: Loco4G63) 04/17/04 01:01 AM
Mine did.
'00 tour with rear drums and abs here
Loco4G63
CEG road warrior
Reged: 08/01/01
Loc: IL
Re: Rear disc's new
#611648 (Re: mattmatt) 05/10/04 05:52 PM
Just did the drum to disc conversion with SS lines.....time to break these bad boys in!
Hector
257HP/259TQ
160HP/141TQ
kontour_sev6
Reged: 04/23/04
Loc: Hurricane Alley, NC
Re: Rear disc's new
#612013 (Re: Loco4G63) 05/10/04 11:38 PM
Is there an issue with getting the parts from the Cougar's if your going to keep the stock 8 spoke 15"ers? Since the Cougars that came with rear discs have 16"ers.
'00 T-Red TourSE 2.5L ATX
Foglight Mod,Optimized Y-Pipe & TB,
FSVT F/P,RU-3530
http://www.cardomain.com/memberpage/688552
gearhead98
Reged: 06/29/03
Loc: Durham NC
Re: Rear disc's new
#651806 (Re: kontour_sev6) 06/28/04 09:28 AM
nope the cougar's disc brake setup is the same as the ones on contour's and they have 15's so you are pretty safe.
anyone correct me if im wrong
98.5 Black SE ATX
S&B filter, SVT MAF, optimized SVT TB, mesh grille, removed orange reflectors, painted rear reflector, gutted pre-cats, optimized SVT LIM, 19lb injectors, resonator removed
cant afford an svt but lookin for 1 in nc
Thinkmoto
Reged: 12/07/02
Loc: Wisconsin
Re: Rear disc's new
#653219 (Re: gearhead98) 06/29/04 07:16 PM
4 wheel disc V6 cougars are the same as 98.5+ SVTs
Early SVTs had slightly bigger calipers different pads and caliper brackets.
98.5 SVTs had the smaller calipers and the offset caliper bracket to make them fit over the bigger rotors. The big difference is the caliper bracket. ON 98.5 SVTs and the V6 4 wheel disc cougars they used a cheaper smaller caliper and made an offset bracket to make it clear the rotor. Contours and Cougars use the same calipers, brackets,and rotors in the rear.... For those equipped with disc brakes that is. Half of my SVT has Cougar brake and suspension parts on it.
06 Pontiac G6 GT
05 CRF250R
ContourGuy9817
Reged: 04/11/04
Loc: Indianapolis, IN
Re: Rear disc's new
#734353 (Re: Thinkmoto) 10/08/04 09:45 AM
could i do it on my I-4 tour? would the cougar knuckles fit?
2002 Cougar
2.5 duratec/ mtx-75
85,0000
Mondeo ST-200 wheels/BFG KDW NT
black/black
Spec Stage 1
Torsen T-2
Trubendz 2.5 flowmaster dual exaust
apexi s-afc II
K&N FIPK
Loco4G63
CEG road warrior
Reged: 08/01/01
Loc: IL
Re: Rear disc's new
#740352 (Re: ContourGuy9817) 10/14/04 10:30 PM
I did it....
Hector
257HP/259TQ
160HP/141TQ
Russell-3L
Reged: 08/23/02
Loc: Pittsburgh, PA
Re: Rear disc's new
#740453 (Re: Loco4G63) 10/15/04 12:50 AM
i got all the aprts needed for the conversion that id be willing to sell...
Russell
Oval Port 3L Nearly Done
MTX75 w/ Homebrew Zetec FD and Torsen Complete
Mystique97
Reged: 07/16/04
Loc: Ashland, Ohio
Re: Rear disc's new
#786884 (Re: Loco4G63) 12/07/04 05:44 PM
Mine did.
My 97 Mystique GS has rear drums with ABS. and Russell how much are you selling those parts for and they will fit on stocks right? I'm on a tight budget must not think about mods ugh
1997 Mercury Mystique GS ZETEC almost 70K and going strong, needs paint work.
Jason G.
1997 Mercury Mystique GS ZETEC ATX
Born: 11/96
Andy W.Moderator
b0x @dm1n
Reged: 07/19/00
Loc: Columbia, MD
Re: Rear disc's new
#795076 (Re: Mystique97) 12/16/04 11:37 AM
Take it to PM's and Classifieds!
-Andy
Andy W.
The problem with America is stupidity.
I'm not saying there should be a capital punishment
for stupidity, but why don't we just take the safety
labels off of everything and let the problem solve itself?
kontour_sev6
Reged: 04/23/04
Re: Rear disc's new
#855686 (Re: Andy W.) 02/22/05 01:07 PM
ford parts online for the following parts was 670.55
FSVT F/P,RU-3530
ToasterOven
Reged: 09/28/05
Loc: Earth. I think...
Re: Rear disc's new
#1103235 (Re: kontour_sev6) 11/17/05 10:16 AM
and this year disc conversion will work on any year/trimline/wheelsize contour?
99 V6SE Sport ATX
R_G
Reged: 05/01/03
Loc: New Jersey
Re: Rear disc's new
#1105038 (Re: ToasterOven) 11/19/05 07:48 AM
IMHO - if this thread is a sticky, it would be greatly appreciated if the mod could sort out the afore information and post a rather organized list of things to get/do.
MY CAR
Loco4G63
CEG road warrior
Reged: 08/01/01
Loc: IL
Re: Rear disc's new
#1105466 (Re: R_G) 11/19/05 10:52 PM
I needed:
Knuckles
New wheel bearings (hub assemblies)
ABS sensors
rotors
pads
calipers
brake hoses
E-brake cable
And essentially that was IT!!! Install was like a 2 hour job....if that.
Hector
257HP/259TQ
160HP/141TQ
R_G
Reged: 05/01/03
Loc: New Jersey
Re: Rear disc's new
#1110191 (Re: Loco4G63) 11/26/05 07:25 AM
Originally posted by LocoGSR:
Knuckles
ABS sensors
rotors
pads
calipers
brake hoses
E-brake cable
Hec - thanks. Now I don't have ABS on my car - does that mean I can exclude it from the list?
MY CAR
R_G
Reged: 05/01/03
Loc: New Jersey
Re: Rear disc's new
#1112008 (Re: R_G) 11/28/05 08:02 PM
Looks like a complete kit - what ya'll think?
Kit on Ebay
MY CAR
Loco4G63
CEG road warrior
Reged: 08/01/01
Loc: IL
Re: Rear disc's new
#1112152 (Re: R_G) 11/28/05 09:39 PM
Knuckles
ABS sensors
rotors
pads
calipers
brake hoses
E-brake cable
Yes....but make sure whatever knuckles you get don't have the ABS.
Hector
257HP/259TQ
160HP/141TQ
BrApple
Reged: 12/23/01
Loc: Enfield, CT
Re: Rear disc's new
#1112297 (Re: Loco4G63) 11/29/05 06:28 AM
Knuckles
ABS sensors
rotors
pads
calipers
brake hoses
E-brake cable
why would it make a difference if you don't have ABS
the abs on the hub are just teeth cut into it, i don't think anything else is different, you just wouldn't need the ABS sensor
- 95 Mystique LS - Zetec/5spd
1ofakindtour
Reged: 09/30/03
Loc: New Jersey
Re: Rear disc's new
#1135928 (Re: BrApple) 12/30/05 09:58 PM
K so here's the question some of us would like to know can I take brakes from an SVT and put them on my 96 NON ABS rear Drum set up? Can I convert without using abs?
Big Jim
Reged: 09/03/00
Re: Rear disc's new
#1135941 (Re: 1ofakindtour) 12/30/05 10:25 PM
Yes. Then you will have the same brakes as a 96 V6 without ABS.
You should know though, that you will get more improvement by putting the front SVT brakes on it even if you keep the rear drums.
Jim Johnson
98 SVT
03 Escape Limited
1ofakindtour
Reged: 09/30/03
Loc: New Jersey
Re: Rear disc's new
#1136052 (Re: Big Jim) 12/31/05 07:24 AM
I was gonna buy the front and back and put them on, just wanted to make sure they'd work without the abs.
hamsterdan
Reged: 01/28/06
Loc: Montreal, Quebec
Re: Rear disc's new
#1156329 (Re: TourDeForce) 01/28/06 01:29 AM
I'm pretty sure ABS is enabled on rear-wheel drum brakes.
I can hear the front brakes hitting the ABS system (Which I don't and will never like), but since it's illegal to unplug or disable anti-lock brakes, I'll live with them.
But I never heard them engage on my rear wheels (drums)
I've only had the car for a couple of months, I have to do the rear brakes, so I could take a peek and come back to you.
On my Cavalier, the ABS would hit way too soon (caused me top rear-end a Protege), on the Contour, I would like them to engage a little later, but they're OK (been criving for the last 16 years.)
1995 4-banger Contour GL
ChattavegasSE
Reged: 11/08/01
Loc: I think I'm banned???
Re: Rear disc's new
#1311407 (Re: hamsterdan) 09/02/06 06:11 PM
There's a feller on ebay selling both rear hubs with the suspension still intact. It'll be a [censored] to ship; maybe the seller will take the suspension parts off and sell 'em. Anyways, they're items 8072084582 and 8072086647.
2000 Contour SE 2.5L ATX - Toreador Red
2001 VW Golf GLS 2.0L MTX - Tornado Red
Buy my possessed VCR!!
0 registered and 1 anonymous users are browsing this forum.
Moderator:  Andy W.
Generated in 0.082 seconds in which 0.055 seconds were spent on a total of 14 queries. Zlib compression enabled.
