Modifications >> Aesthetics
Pages: 1 | 2 | (show all)
m4gician
Reged: 06/05/06
Loc: Toronto (Woodbridge)
HOW-TO: Paint Interior Trim for DIY DASH KITS!
#1308391 - 08/29/06 03:35 AM
Okay this is a very easy mod to do yourself, especially if you want to make your interior look a little more to your style. Basically what you will be doing is taking apart the interior trim panels and painting them as you would if you were painting anything outside. The goal here is to have something that has a clear coat on it that can be waxed to produce a great shine. There are SO MANY ideas for you to choose from. For that sake of simplicity, I'm going to show you what I did with Radiant Silver as a colour, though there was some paint out there for abut $30, which would produce either a metalic or mystify look but I cheaped out and got the $5 paint .
WHAT YOU WILL NEED:
- 150, 220, and 400 grit sand paper
- Sandable spray primer,
- Colour base coat of your choice
- Clear Top Coat
- Philips head screw driver.
OPTIONAL:
- Box with lots of news paper (to prevent mess)
- PATIENCE (results come out great if you wait).
- Automotive PAINTER's tape (really makes things easier)
Step 1: Remove the trim pieces you want to paint, to make this simple I just removed the trim pieces on the doors, though I have already painted the HVAC, the right passenger vent, the headlight trim, and I'm still trying to decide what to do with the main dash cover...
Here in the picture are all the materials you need/that I used.
And here you'll see my dash is off, and I'm contemplating a pattern.
Step 2: Prep the pieces by sanding them with 220 grit paper. I started with 150 but that was because of the scratches and marks on them already, all you really need is 220 then spray with primer.
Step 3: Spray EVENLY at about 10 to 12 inches away and do QUICK light coats of primer (I'm not over or underestimating, do that please). And allow a good 1 1/2hrs to 2hrs to dry and cure.
Step 4: Spray EVENLY at about 10 to 12 inches away and do QUICK light coats of BASE COAT. ALlow a good 3 to 5 hours to cure and dry in the SUN of if possible
Step 5: After the base has cured/dried, spray on the clear coat in the same manner.
Step 6: Allow the clear coat to dry, then wash the trim pieces and apply a wax to them .
Here's a pic of the final results.
I'm planning to paint the bottom of the door on the inside, (the trim piece that goes from the door handle and becomes a little cubby space just to match.
1998 Mercury Mystique LS
mystiquevltwin
Reged: 01/28/05
Loc: pittsburgh PA
Re: HOW-TO: Paint Interior Trim for DIY DASH KITS! new
#1308944 (Re: m4gician) 08/30/06 12:46 AM
looking good! and a good how-to!
btw, what is that big button on your drivers window switch??
kevin m
98 T-red mystique gs
zetec ATX
| my ride |
m4gician
Reged: 06/05/06
#1309136 (Re: mystiquevltwin) 08/30/06 04:30 AM
oh on the mystiques with the AUTO down window, you get a big button. It's standard now on most cars but that's what it is. Just to signify auto down.
starjammir
Reged: 08/14/04
Loc: Lapeer, Mi
#1309406 (Re: m4gician) 08/30/06 06:17 PM
My mystique has auto down but no big button
1998.5 SVT contour #5979 3L
1995 Mercury Mystique 2.5L auto, all ghetto fo sho
mystiquevltwin
Reged: 01/28/05
Loc: pittsburgh PA
#1309501 (Re: starjammir) 08/30/06 09:11 PM
ditto
kevin m
zetec ATX
| my ride |
m4gician
Reged: 06/05/06
#1309599 (Re: starjammir) 08/30/06 11:53 PM
mine is not 1998.5 D: it;s just 98, probablyh that's why.
starjammir
Reged: 08/14/04
Loc: Lapeer, Mi
#1309650 (Re: m4gician) 08/31/06 01:03 AM
mine is a 95
amarv12
Reged: 05/12/02
Loc: Michigan
#1309688 (Re: starjammir) 08/31/06 01:32 AM
My car is an early 98, doesn't have the bulge either...but i bought switches from NVS mystiques old stique and it did have the bulge ...always thought it was weird....wonder if its a canadia thing?
As i understand it the bulge ones allow you to choose auto-down or manual...whereas the non-bulge automatically do the auto down.
1998 Mystique LS:
-2.5 Duratec ATX
-Vibrant White
=Pics=
=Info=
IRingTwyce
Reged: 07/01/03
Loc: Graham, TX
#1309722 (Re: amarv12) 08/31/06 02:00 AM
I think the non-bulge auto-down switches are the same as the ones in the Contour. If so, they are actually a two position switch. If you press it lightly, the switch works like all the others. Window stops when you let up. If you press harder, you'll trigger the auto-down. Play with your switch some and you'll see what I mean.
Berkel
Reged: 10/08/05
Loc: Toledo
#1309755 (Re: IRingTwyce) 08/31/06 02:44 AM
98.5 T. Red Contour SVT
Lowered on FSVT's
http://www.cardomain.com/ride/2154233
Nezerconezer
Reged: 07/04/06
Loc: PHX AZ
#1312536 (Re: Berkel) 09/05/06 07:32 AM
Hm my 99 mystique and 00 svt doesn't have that button. Was it an option.
Moderator:  GTO Pete
Generated in 0.103 seconds in which 0.096 seconds were spent on a total of 14 queries. Zlib compression enabled.
