Modifications >> 3.0L Duratec
Pages: 1
m4gician
Reged: 06/05/06
Loc: Toronto (Woodbridge)
pulling my own 3L from a junk car...
#1306934 - 08/26/06 03:14 PM
I saw a 3L block from a 03 Taurus I believe that looks pretty well intact, and the mileage only reads about 102,000km or about 60,500 miles? The yard I go to told me if I pull the whole thing out myself it'll only cost me $100 for the entire thing...is that a good deal to start my 3L project? Or am I in a world of hurt trying to do it myself and just should go for those blocks already pulled (aka the $500 budget ones) ?
1998 Mercury Mystique LS
stilov
Reged: 08/20/03
Loc: CO
Re: pulling my own 3L from a junk car... new
#1306966 (Re: m4gician) 08/26/06 05:45 PM
I bought an 03 shipped to a local pickup station with 2k yes two thousand miles for either 250 or 350...I don't remeber which one.
98 E0 SVT with some stuff
TourDeForce
Reged: 03/04/03
#1306996 (Re: m4gician) 08/26/06 07:36 PM
There's more to it than just pulling the engine. Compression check for one. Maybe you can do that before pulling it, then it might be worth a try if the compression tests pass.
You should still consider a bottom end rebuild & properly grease up the new bearings & such.
m4gician
Reged: 06/05/06
#1307089 (Re: TourDeForce) 08/26/06 11:17 PM
ya I know, it'd be a long job with maybe someone else probably going to be like 2 or 3 people going at it.
weargle
Reged: 03/06/03
Loc: Morrisville, NC
#1309559 (Re: m4gician) 08/30/06 10:47 PM
What're you willing to cut? Pull two axles, cut some wires and radiator hoses and power steering lines, Sawzall the exhaust, bleed the AC, unbolt the mounts and pull up. You don't care about the donor car, do you?
Whirling dervish of FFOG.
Buckshot77
Learned patience the hard way
Reged: 11/24/00
Loc: Des Moines, IA USA
#1309998 (Re: m4gician) 08/31/06 02:01 PM
I pulled one of my own engines and it wasn't necessarily a cakewalk and I've installed over a dozen engines in contours and cougars. The taurus has a bit different structure that you've got to work around, but most of that can be torched or sawzalled through to get it done quickly. You can hack the wiring harnesses since it's not being reused along with all the hoses, tubing, etc. The particular car I was working on all ready had the front clip off and the hood/fenders were gone as well. It still took me 3-4 solid hours just hacking away at everything. The longest part of the process was unbolting the torque converter from the trans. The bolts are a PITA to get to.
All in all, I'd say most of the time it's worth having the junkyard pull and prep the motor unless you have nothing better to do with your time.
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
Pandrone
Newbie
Reged: 07/25/06
#1311253 (Re: Buckshot77) 09/02/06 05:16 PM
Hi
Would a engine from a 1994 or 1996 Ford Taurus do it? I mean can i do a 3L conversion with that block?
Buckshot77
Reged: 11/24/00
#1311297 (Re: Pandrone) 09/02/06 07:10 PM
Don't bother with it.
Rick
Buckshot77@msn.com
Pandrone
Newbie
Reged: 07/25/06
#1311358 (Re: Buckshot77) 09/02/06 09:29 PM
Rick
What about an block from an Mondeo ST220? though i think it has high compression pistons, and if i would like to turbocharge i would want low compression, i could change parts but it would save me some money getting away with original pistons, rods, crank in the beginning (thinking of low boost pressure for everyday driving).
This conversion/turbo thing is something that will grow over some years if i will do it.
Pages: 1
0 registered and 16 anonymous users are browsing this forum.
Moderator:  bnoon, PA 3L SVT
Generated in 0.026 seconds in which 0.02 seconds were spent on a total of 14 queries. Zlib compression enabled.
