How do you have these final drives? If you read up on the mtx 75 the differential doesn't make the final drive. It is the ring gear and pinion SET. And if you read from Terry Haines website you need the set and the right transmission parts to go with it. Pinion is machined to shaft in transmission that holds other gears.
