solo92s10
Finally got to look at the rear calipers and after disconnecting the rear caliper from the flex line i noticed the caliper only had a few drops of fluid in it and the flex hose had none. So i disconnected the flex hose from the thing in the pic and applied brake pressure and still nothing so I disconnected the hard line from the thing in my hand in the picture and fluid would gravity flow if i took the cap off the resevoir. So in my conclusion the thing in my hand is what is wrong with my drivers rear brakes. Now the question i have is what is it called and where can i buy it? I assume it regulates pressure to that caliper but other than that assumption i know nothing about it. Thanks
