Thickness
so i have a 99 t green with a return style fuel system. I have a walbro 255lph pump for a mustang that i thought was going to be a direct fit but it seems some modifying needs to be done to the bottom portion of the bracket that the pump sits in, does anything sound wrong here? Its a buddies car im workin on and i don't wanna have to replace his sending unit. Ive tried searching but only found results for an fsvt install witch i thought should be close to the same. Lemme know wacha you guys know, thanks
