Ford F-350 Man
Well we'll start off with the vibration issues... Now it seems no matter what the speed the car vibrates, I had all four tires re-balanced, they were all out of balance... But it still vibrates, I even replaced the driver's side CV axle, still vibrated just as bad... So I then replaced the bushing on the driver's side, the new bushing has about the same amount of play as the old bushing, albeit a tiny bit less... So I just re-installed the old CV axle and saved what would have been a waste of money... I can hear a howling noise, so obviously it needs new wheel bearings... That may be the whole problem right there, I don't know... It seems like at low speed the driver's side of the car "flops" constantly so to speak, you can feel it and almost watch it go up and down sort of...
Now let's move onto the fuel issue... Well it's more like two issues... Fuel delivery and fuel level... I have a fuel level code (non MIL) and a pending fuel pressure code, MIL light is not on right now... I had to replace the pump since the original one finally died before I got the car... I got an eBay special fuel pump for $21... If I fill up the tank I can go between 90 - 110 miles before it starts screwing up on me... So basically it can go through around 4 gallons of gas which is a little below 3/4 tank from full, before it starts screwing up on me and I have to find a gas station... I will say this, the rubber check valve on the bottom of the pickup assembly has a tear in it, so it can no longer seal anymore... I've been thinking that may be the problem right there... The pickup assembly was replaced in this car in 2001, and it's been in there original all the way until the fuel pump died in it this year... I can get an entire updated Carter P74954M pickup assembly for $149.95, so I may just get it...
As for the fuel level, I know the sending unit is good, it has varying resistances like it's suppose to, and good continuity to the plug on the outside of the cover... So either the gauge is bad or the wiring between the tank and PCM is toast...
Now onto the shifting issues... First off it obviously needs a fluid change, the ATF is pretty ripe looking... But that's not the main issue. The issue is when I floor the gas it won't shift out of first, I have to manually put it into second, and unfortunately I can't do it for third as well... But if I drive it normally it shifts just fine... But once today I decided to floor it, and it actually shifted perfectly, I was impressed... So I'm thinking it may be the control solenoid... The shifting problem isn't that big of an issue really, but I would still like to fix it though...
If you guys can help me with these issues that would be great... I'm trying to sell this car, but I know there's no way I can get what I'm asking for it if I don't fix these issues...
