to optimize, or not to optimize
1BadJag
Fredericksburg, VA
... yes i have searched.... and seach. But im still stuck on what to do! Should i
1) optimize the stock y pipe on my 98 csvt.
2) Get money together and go for the BAT inc ypipe/cat w/ flexpipe(400$ ugh)?
Need some honest opinions. What gives more power? Is the Cost of the BAT ypipe worth it?
opt the stock pipe. :cool:
i looked for the how to.... disappeared maybe?
the links are down because ceg is under construction.
It's pretty simple. Cut the y-pipe...remove the center bar with a grinder...and then reweld the pipe back in place.:cool:
TO be honest..i'm over hauling the entire exhaust section. It needs to be done!
I will have every area covered and i will most def cover the y-pipe section. It's currently my only section left to tackle. So check back in 2 weeks with coffee and your reading glasses :)
lol good deal. is it possible to NOT cut the ypipe open and use a torch on the divider? i would hate to hack my ypipe up and be out of my DD for a few days
Torching won't do anything.
You can grind down the center bar a bit with a grinder.
Take a moment and look at trubendz for their custom y-pipes they offer us.
