Hiya! I was using a 65mm tb on my 2.5+3.0 UIM. It runs with no problem.
I installed a 75mm BBK tb a while ago, for testing purpose. It ran fine.
But a DTC code came up: P1121 Throttle Position Sensor Inconsistent With MAF Sensor High Voltage.
I've checked, there were no leaks and TP sensor was good.
TPS% is 16.8% at idle and 93.0% at WOT.
I noticed the TPS mounting screws on the BBK tb weren't vertical like stock ones. Could this be the problem?
The car is quite fine even when this DTC came up, though.
Has anyone got an idea how to solve this?
BTW, what is the TPS% of idle and WOT for stock tb+UIM?
