BurritaSVT
Well I was able to get the motor back together in the car and was only able to get 200 miles on the clutch. I installed a 04 Taurus motor no porting just my LIM mod and the SVT UIM with 42# injectors. The car is equipped with focus SVT pump and 80mm MAF and has SVT cams in the engine. The kit is the new SS turbo kits which I just changed over too we have a 8 psi spring in the car baseline kit with a T04E 60 trim turbo with a 63A/R turbine stage 3 wheel. We do have the upgraded FMIC and the larger BOV RFL. I managed to make 6 pulls on the dyno where I had to dial in the A/F because the car made so much torque the clutch was slipping on the road to tune the WOT settings. I was very impressed to say we made 260whp with 275 wtq on std settings meaning the car is making that power on the dyno but corrected the in SAE made 354whp with 366wtq more than you can expect out of a stock 3 liter block. The boost guage would flutter to 9 psi then drop to 8.5 psi up top. The car is really fast and delivers the power smooth and fast I can't believe that stock motor will make 400hp and 410tq on just a 8 pound spring and on a 10:1.1 CR wow take a look............
actual dyno numbers here
