rexxdoggy
Okay, so I'm looking at a problem with my solenoid starting to go, started happening today. Grinding noise when I turn the key, try it again, same problem, try it again, starts up no problem. Anyways, I'm looking at replacing the starter when I do the solenoid replacement, as well. I've looked on rockauto and seen that the starters are all remanufactured. Should I be staying away from remanufactured or will they be fine?
Thanks.
Thanks.
