A3ON
ok , i have a mildly stock 95 2.5 se mtx. The clutch was fried when i bought the car so about 2 years ago i replaced it with a spec stage 3 and a nice fidanza flywheel. Now my clutch is slipping in high gears and low rpm's @ 3/4 throttle when i give it gas. But the take off engagement feels fine , also i can shift fine. Possibly a leaking slave cylinder? , or a leaking rear main seal? or is the disk/flywheel fried?. If i need to replace can the trans be pulled w/o removing the whole subframe as i do not have the necessities to put my car on a lift. thanks for the imput
